VG224 not registered
Hello All,
i configured VG224 with CUCM 8.6 but it not registering and getting bellow error
ANALOGGW-01#u
001961: *Apr 11 15:32:20.359 EDT: SCCP(ANB7487A9E31405)send RegisterMessage, protocol_ver=0x11000102
001962: *Apr 11 15:32:20.359 EDT: SCCP(ANB7487A9E31405)send IpPortMessage
001963: *Apr 11 15:32:20.363 EDT: SCCP(ANB7487A9E31405)rcvd RegisterRejectMessage
001964: *Apr 11 15:32:20.363 EDT: SCCP(ANB7487A9E31405)rcvd register rej reason: Security Error
my configration shows below
VG224 GW:
stcapp ccm-group 1
stcapp
voice-port 2/0
timeouts ringing infinity
sccp local FastEthernet0/1.920
sccp ccm 10.62.124.31 identifier 3 version 7.0
sccp ccm 10.63.124.52 identifier 2 version 7.0
sccp ccm 10.61.8.41 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface FastEthernet0/1.920
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
switchback method graceful
dial-peer voice 600 pots
service stcapp
port 2/0
ANALOGGW-01#sh sccp
SCCP Admin State: UP
Gateway Local Interface: FastEthernet0/1.920
        IPv4 Address: 10.61.8.13
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.62.124.31, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 3
                Trustpoint: N/A
Call Manager: 10.63.124.52, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 2
                Trustpoint: N/A
Call Manager: 10.61.8.41, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 1
                Trustpoint: N/A
Alg_Phone Oper State: ACTIVE_IN_PROGRESS - Cause Code: CCM_REGISTER_FAILED
Active Call Manager: 10.61.8.41, Port Number: 2000
TCP Link Status: NOT_CONNECTED, Device Name: ANB7487A9E31400
Reported Max Streams: 1, Reported Max OOS Streams: 0
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: g711ulaw, Maximum Packetization Period: 20
Supported Codec: g711alaw, Maximum Packetization Period: 20
Supported Codec: g729r8, Maximum Packetization Period: 220
Supported Codec: g729ar8, Maximum Packetization Period: 220
Supported Codec: g729br8, Maximum Packetization Period: 220
Supported Codec: ilbc, Maximum Packetization Period: 120
Leonardo Santana
How is configured on CUCM? Can you post an screenshoot!
Did you configure the last 10 digits of the Mac Address of you interface?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
sorry i forgot to add in this post
yes i configured as gateway as SCCP with last 10 digit of VG224 mac. i did same configuration that working with other cucm cluster
can you post the this commands outputs:
show stcapp device summary
sh sccp all
Leonardo Santana
See attached file
