VG224 Port MIssing
dtom
When we type the command "sh sccp" we see the following:
Alg_Phone Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 10.223.250.13, Port Number: 2000
TCP Link Status: CONNECTED, Device Name: ANF70D020622414
Reported Max Streams: 1, Reported Max OOS Streams: 0
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: g711ulaw, Maximum Packetization Period: 20
Supported Codec: g711alaw, Maximum Packetization Period: 20
Supported Codec: g729r8, Maximum Packetization Period: 220
Supported Codec: g729ar8, Maximum Packetization Period: 220
Supported Codec: g729br8, Maximum Packetization Period: 220
Supported Codec: ilbc, Maximum Packetization Period: 120
TCP Link Status: CONNECTED, Device Name: ANF70D020622416
It appears that port ANF70D020622415 is missing.  We have rebooted the VG224 with no change and tried to reset the port with no change.  Any thoughts here?
Chris Deren
Can you post your "show run"?
vg224-kingscanyon-m-2#
vg224-kingscanyon-m-2#sh run
Building configuration...
Current configuration : 7384 bytes
version 12.4
no service pad
service password-encryption
hostname vg224-kingscanyon-m-2
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
ip cef
ip domain name fresnounified.org
ip name-server 10.223.192.132
ip name-server 10.223.192.133
ip name-server 10.223.231.12
ip name-server 10.223.241.12
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp feature speed-dial
voice service voip
voice-card 0
username micros privilege 7 secret 5 $1$hytM$kqy0rVcCC0BQZiwQVnAzL.
username fusd privilege 15 secret 5 $1$g7uZ$FLVnZJb3c4MkI4A.9.E5M.
archive
 log config
  hidekeys
interface FastEthernet0/0
 ip address 10.74.160.5 255.255.240.0
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.74.160.1
no ip http server
snmp-server community EZBEAR RO
snmp-server location Custodial Closet by Rm15
snmp-server contact Network & Engineering
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps xgcp
snmp-server enable traps aaa_server
snmp-server enable traps config
snmp-server enable traps config-ctid
snmp-server enable traps envmon
snmp-server enable traps flash insertion removal
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps rsvp
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps cpu threshold
snmp-server enable traps resource-policy
snmp-server enable traps config-copy
snmp-server enable traps ipsla
snmp-server enable traps syslog
snmp-server enable traps dial
snmp-server enable traps dsp card-status
snmp-server enable traps dsp oper-state
snmp-server enable traps pppoe
snmp-server enable traps l2tun session
snmp-server enable traps l2tun pseudowire status
snmp-server enable traps memory bufferpeak
snmp-server enable traps event-manager
snmp-server enable traps voice
snmp-server enable traps dnis
control-plane
voice-port 2/0
 mwi
 timeouts initial 60
 timeouts interdigit 60
 timeouts ringing infinity
voice-port 2/1
 mwi
 timeouts initial 60
voice-port 2/2
 mwi
 timeouts initial 60
voice-port 2/3
 mwi
 timeouts initial 60
voice-port 2/4
 mwi
 timeouts initial 60
voice-port 2/5
 mwi
 timeouts initial 60
voice-port 2/6
 mwi
 timeouts initial 60
voice-port 2/7
 mwi
 timeouts initial 60
voice-port 2/8
 mwi
 timeouts initial 60
voice-port 2/9
 mwi
 timeouts initial 60
voice-port 2/10
 mwi
 timeouts initial 60
voice-port 2/11
 mwi
 timeouts initial 60
voice-port 2/12
 mwi
 timeouts initial 60
voice-port 2/13
 mwi
 timeouts initial 60
voice-port 2/14
 mwi
 timeouts initial 60
voice-port 2/15
 mwi
 timeouts initial 60
voice-port 2/16
 mwi
 timeouts initial 60
voice-port 2/17
 mwi
 timeouts initial 60
voice-port 2/18
 mwi
 timeouts initial 60
voice-port 2/19
 mwi
 timeouts initial 60
voice-port 2/20
 mwi
 timeouts initial 60
voice-port 2/21
 mwi
 timeouts initial 60
voice-port 2/22
 mwi
 timeouts initial 60
voice-port 2/23
 mwi
 timeouts initial 60
ccm-manager fax protocol cisco
ccm-manager config server cucm-sub3 cucm-pub1
ccm-manager config
ccm-manager sccp local FastEthernet0/0
ccm-manager sccp
sccp ccm 10.74.160.2 identifier 3 version 7.0
sccp ccm 10.223.250.15 identifier 2 version 7.0
sccp ccm 10.223.250.13 identifier 1 version 7.0
sccp
sccp ccm group 1
 bind interface FastEthernet0/0
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate ccm 3 priority 3
 switchback method graceful
dial-peer voice 999200 pots
 service stcapp
 port 2/0
dial-peer voice 999201 pots
 service stcapp
 port 2/1
dial-peer voice 999202 pots
 service stcapp
 port 2/2
dial-peer voice 999203 pots
 service stcapp
 port 2/3
dial-peer voice 999204 pots
 service stcapp
 port 2/4
dial-peer voice 999205 pots
 service stcapp
 port 2/5
dial-peer voice 999206 pots
 service stcapp
 port 2/6
dial-peer voice 999207 pots
 service stcapp
 port 2/7
dial-peer voice 999208 pots
 service stcapp
 port 2/8
dial-peer voice 999209 pots
 service stcapp
 port 2/9
dial-peer voice 9992010 pots
 service stcapp
 port 2/10
dial-peer voice 9992011 pots
 service stcapp
 port 2/11
dial-peer voice 9992012 pots
 service stcapp
 port 2/12
dial-peer voice 9992013 pots
 service stcapp
 port 2/13
dial-peer voice 9992014 pots
 service stcapp
 port 2/14
dial-peer voice 9992015 pots
 service stcapp
 port 2/15
dial-peer voice 9992016 pots
 service stcapp
 port 2/16
dial-peer voice 9992017 pots
 service stcapp
 port 2/17
dial-peer voice 9992018 pots
 service stcapp
 port 2/18
dial-peer voice 9992019 pots
 service stcapp
 port 2/19
dial-peer voice 9992020 pots
 service stcapp
 port 2/20
dial-peer voice 9992021 pots
 service stcapp
 port 2/21
dial-peer voice 9992022 pots
 service stcapp
 port 2/22
dial-peer voice 9992023 pots
 service stcapp
 port 2/23
banner login ^CC
 W A R N I N G
Unauthorized access to this system is forbidden and will be
prosecuted by law. By accessing this system, you agree that your
actions may be monitored if unauthorized usage is suspected.
^C
privilege exec level 7 show running-config view full
line con 0
 login local
line aux 0
line vty 0 4
 login local
 transport input all
end
