03-24-2017 09:05 AM - edited 03-17-2019 09:53 AM
When we type the command "sh sccp" we see the following:
Alg_Phone Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 10.223.250.13, Port Number: 2000
TCP Link Status: CONNECTED, Device Name: ANF70D020622414
Reported Max Streams: 1, Reported Max OOS Streams: 0
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: g711ulaw, Maximum Packetization Period: 20
Supported Codec: g711alaw, Maximum Packetization Period: 20
Supported Codec: g729r8, Maximum Packetization Period: 220
Supported Codec: g729ar8, Maximum Packetization Period: 220
Supported Codec: g729br8, Maximum Packetization Period: 220
Supported Codec: ilbc, Maximum Packetization Period: 120
TCP Link Status: CONNECTED, Device Name: ANF70D020622416
It appears that port ANF70D020622415 is missing. We have rebooted the VG224 with no change and tried to reset the port with no change. Any thoughts here?
03-24-2017 09:46 AM
Can you post your "show run"?
03-24-2017 12:28 PM
vg224-kingscanyon-m-2#
vg224-kingscanyon-m-2#sh run
Building configuration...
Current configuration : 7384 bytes
version 12.4
no service pad
service password-encryption
hostname vg224-kingscanyon-m-2
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
ip cef
ip domain name fresnounified.org
ip name-server 10.223.192.132
ip name-server 10.223.192.133
ip name-server 10.223.231.12
ip name-server 10.223.241.12
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp feature speed-dial
voice service voip
voice-card 0
username micros privilege 7 secret 5 $1$hytM$kqy0rVcCC0BQZiwQVnAzL.
username fusd privilege 15 secret 5 $1$g7uZ$FLVnZJb3c4MkI4A.9.E5M.
archive
log config
hidekeys
interface FastEthernet0/0
ip address 10.74.160.5 255.255.240.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.74.160.1
no ip http server
snmp-server community EZBEAR RO
snmp-server location Custodial Closet by Rm15
snmp-server contact Network & Engineering
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps xgcp
snmp-server enable traps aaa_server
snmp-server enable traps config
snmp-server enable traps config-ctid
snmp-server enable traps envmon
snmp-server enable traps flash insertion removal
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps rsvp
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps cpu threshold
snmp-server enable traps resource-policy
snmp-server enable traps config-copy
snmp-server enable traps ipsla
snmp-server enable traps syslog
snmp-server enable traps dial
snmp-server enable traps dsp card-status
snmp-server enable traps dsp oper-state
snmp-server enable traps pppoe
snmp-server enable traps l2tun session
snmp-server enable traps l2tun pseudowire status
snmp-server enable traps memory bufferpeak
snmp-server enable traps event-manager
snmp-server enable traps voice
snmp-server enable traps dnis
control-plane
voice-port 2/0
mwi
timeouts initial 60
timeouts interdigit 60
timeouts ringing infinity
voice-port 2/1
mwi
timeouts initial 60
voice-port 2/2
mwi
timeouts initial 60
voice-port 2/3
mwi
timeouts initial 60
voice-port 2/4
mwi
timeouts initial 60
voice-port 2/5
mwi
timeouts initial 60
voice-port 2/6
mwi
timeouts initial 60
voice-port 2/7
mwi
timeouts initial 60
voice-port 2/8
mwi
timeouts initial 60
voice-port 2/9
mwi
timeouts initial 60
voice-port 2/10
mwi
timeouts initial 60
voice-port 2/11
mwi
timeouts initial 60
voice-port 2/12
mwi
timeouts initial 60
voice-port 2/13
mwi
timeouts initial 60
voice-port 2/14
mwi
timeouts initial 60
voice-port 2/15
mwi
timeouts initial 60
voice-port 2/16
mwi
timeouts initial 60
voice-port 2/17
mwi
timeouts initial 60
voice-port 2/18
mwi
timeouts initial 60
voice-port 2/19
mwi
timeouts initial 60
voice-port 2/20
mwi
timeouts initial 60
voice-port 2/21
mwi
timeouts initial 60
voice-port 2/22
mwi
timeouts initial 60
voice-port 2/23
mwi
timeouts initial 60
ccm-manager fax protocol cisco
ccm-manager config server cucm-sub3 cucm-pub1
ccm-manager config
ccm-manager sccp local FastEthernet0/0
ccm-manager sccp
sccp ccm 10.74.160.2 identifier 3 version 7.0
sccp ccm 10.223.250.15 identifier 2 version 7.0
sccp ccm 10.223.250.13 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
switchback method graceful
dial-peer voice 999200 pots
service stcapp
port 2/0
dial-peer voice 999201 pots
service stcapp
port 2/1
dial-peer voice 999202 pots
service stcapp
port 2/2
dial-peer voice 999203 pots
service stcapp
port 2/3
dial-peer voice 999204 pots
service stcapp
port 2/4
dial-peer voice 999205 pots
service stcapp
port 2/5
dial-peer voice 999206 pots
service stcapp
port 2/6
dial-peer voice 999207 pots
service stcapp
port 2/7
dial-peer voice 999208 pots
service stcapp
port 2/8
dial-peer voice 999209 pots
service stcapp
port 2/9
dial-peer voice 9992010 pots
service stcapp
port 2/10
dial-peer voice 9992011 pots
service stcapp
port 2/11
dial-peer voice 9992012 pots
service stcapp
port 2/12
dial-peer voice 9992013 pots
service stcapp
port 2/13
dial-peer voice 9992014 pots
service stcapp
port 2/14
dial-peer voice 9992015 pots
service stcapp
port 2/15
dial-peer voice 9992016 pots
service stcapp
port 2/16
dial-peer voice 9992017 pots
service stcapp
port 2/17
dial-peer voice 9992018 pots
service stcapp
port 2/18
dial-peer voice 9992019 pots
service stcapp
port 2/19
dial-peer voice 9992020 pots
service stcapp
port 2/20
dial-peer voice 9992021 pots
service stcapp
port 2/21
dial-peer voice 9992022 pots
service stcapp
port 2/22
dial-peer voice 9992023 pots
service stcapp
port 2/23
banner login ^CC
W A R N I N G
Unauthorized access to this system is forbidden and will be
prosecuted by law. By accessing this system, you agree that your
actions may be monitored if unauthorized usage is suspected.
^C
privilege exec level 7 show running-config view full
line con 0
login local
line aux 0
line vty 0 4
login local
transport input all
end
