Beginner
VG224 Redundancy Loopback to Core's 6500
Good day, now I have two 6500 switches as CORE, interconnected with PortChannel, I connect a VG224 which has 2 FastEthernet ports and an interface Loopback0, copper ports every 6500, I would like to have redundancy in L3 through OSPF, but unsubscribe when the interface which is connected to the VG224 6500th comunicacion.y lose him no redundancy 6500B, as someone could help achieve redundancy????
Core1
interface FastEthernet1/25
description Core1 a VG224
ip address X.X.15.25 255.255.255.252
ip ospf authentication message-digest
ip ospf message-digest-key
speed 100
duplex full
Core2
description Core2 a Vg224
ip address X.X.18.25 255.255.255.252
speed 100
duplex full
VG224
interface Loopback0
ip address 10.11.0.135 255.255.255.255
interface FastEthernet0/0
description VG224 a Core1
ip address X.X.15.26 255.255.255.252
ip ospf priority 0
duplex full
speed 100
interface FastEthernet0/1
description VG224 a Core2
ip address X.X.18.26 255.255.255.252
ip ospf cost 100
ip ospf priority 0
duplex full
speed 100
Everyone's tags (4)
2 REPLIES 2
Highlighted
Hall of Fame Master
This has been asked here many times before, VG224 does not support etherchannel, so your options are routing protocol of BVI, one example below, many others available:
https://supportforums.cisco.com/message/1169065#1169065
HTH,
Chris
Highlighted
Beginner
Thanks Chris...
The EtherChannel is configured between Switches 6500, what I would like is to connect a VG interface to each Switch 6500 and have a L3 redundancy will have some idea???
