11-16-2013 04:47 AM - edited 03-16-2019 08:26 PM
hi,
recently i have changed the domain name of a VG224, before the change, all ports shows "registered" from the CUCM.
after I changed the domain name from VG224 and CUCM, the VG224 can be registered to CUCM, and some ports can register too...only serveral ports showing "unregistered" in the CUCM. But from the VG224, everything is normal. and call/ fax can be made successfully from those "unregistered" ports.
anyone has idea what's going on?
thanks.
11-16-2013 04:18 PM
Melany,
Can you check on your vg224 if you have a domain name set like:-
ip domain name anynet.com
If you have you will need to use an FQDN on the CUCM domain field like:-
vg224.anynet.com
changing just the routers hostname and the CUCM may not be enough
Alex.
Please rate useful posts.
11-16-2013 05:03 PM
Yes, I am exactly changing the domain name in the vg224 and using fqdn in cucm, my vg224 can register ...only few ports have problem :(
11-16-2013 05:26 PM
Melany,
Try restarting the mgcp on the vg224
conf t
no mgcp
mgcp
end
Alex.
11-16-2013 05:48 PM
Tried restarting mgcp and reset gateway in cucm....still the same few port has problem...
But when I reverted the domain name to the old one....problem gone....:(
11-18-2013 03:40 PM
Melany,
Sorry for the delay,
I have had a look at bugs etc.
The only one I can find that may be related is:-
Change MGCP gateway Domain Name only reset endpoints not whole gateway
Symptom:
Incoming and outgoing calls over an MGCP gateway fails randomly after changing gateway's domain name in CallManager. Sometimes caller receives dead air.
Conditions:
The administrator changes the gateway domain name in CCM without stopping Gateway's mgcp service.
Workaround:
Reset or reload the gateway.
Further Problem Description:
The proper way of changing a gateway's domain name is:
- Stop Gateway's mgcp service (gateway command: no mgcp)
- Chnage the domain name in the gateway and in CCM.
- Start Gateway's mgcp service (gateway command: mgcp)
Customer Visible
Was the description about this Bug Helpful?
(0)
Last Modified:
Nov 2,2012
Status:
Fixed
Severity:
3 Moderate
Product:
Cisco Unified Communications Manager (CallManager)
Support Cases:
Known Affected Releases: | (1) |
4.2
Known Fixed Releases: | (4) |
6.0(0.9901.37)
6.0(1.1000.37)
7.0(0.99999.65)
1.0(0.98000.42)
Download software for Cisco Unified Communications Manager (CallManager)
Support Cases: | (2) |
Support case links are not customer visible
Related Bugs
Bug(s)
Community Discussion on CSCsg39923 - Cisco Support Community
Alex.
