03-04-2016 06:08 AM - edited 03-18-2019 11:50 AM
VG224 is not supported with CUCM 11.X?
At the matrix of compatibility does not show the recommended IOS Version.
Leonardo Santana
03-04-2016 06:30 AM
Hi Tadeu,
checked the link shared you which shows vg224 as Blank in CUCM 10.5.
Not aware whether VG224 is supported with CUCM11 but I checked in CUCM 10.5.1 , VG 224/VG202/VG310/VG320/VG350 are supported .
regds,
aman
03-04-2016 07:51 AM
It is supported, you probably want to use a higher release (if available) from the one listed on 10.5, or at the bare minimum, the same as 10.5
