04-29-2015 10:22 AM - edited 03-17-2019 02:51 AM
We currently run System version: 8.6.2.20000-2 Unrestricted. I see where a minimum of 9.2xxx is required to utilize VG310 & 320 Gateways. We are upgrading to a version 10.x, but not 10.5. Is 10.5 required to support these devices OR can one of the earlier 10.x releases support them? I have seen at least one document that says 10.5 is required.
Solved! Go to Solution.
04-29-2015 11:53 AM
You only require 9.1(2)SU2 or later as the minimum, you can go higher if you want, if you're going to 10.x, I strongly suggest 105(2)
04-29-2015 11:53 AM
04-29-2015 12:11 PM
That's likely what we'll do. Hopefully, the upgrade path from 8.6 isn't too bad.
