08-28-2017 09:46 PM - edited 03-17-2019 11:04 AM
Hello, Anyone know why a port would be up/up off-hook when nothing's configured on these ports and nothing's actually patched in? Thankyou in advance
Test-vg320#show voice port summ
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/0/0 -- fxs-ls up up off-hook idle y
0/0/1 -- fxs-ls up dorm on-hook idle y
0/0/2 -- fxs-ls up up off-hook idle y
0/0/3 -- fxs-ls up up off-hook idle y
08-29-2017 01:24 AM
Do they stay in the same state even if you reload the router? Can you share the running config from the router.
Manish
- Do rate useful posts -
08-29-2017 04:19 AM
Hi, thankyou for your response.
Yes rebooted the VG and still the ports are 'stuck' in up/up off hook. Will post the config soon.
08-29-2017 10:36 AM
Are you using SCCP registration for VG320. If so then its expected as the voice-ports of VG320 are registered with CME using SCCP therefore voice-ports will be up/up representing ephone-dns/ephones.
