05-17-2017 01:34 PM - edited 03-17-2019 10:21 AM
I have configured VG350 with following command
ccm-manager config server 142.100.65.11
ccm-manager config
But it is not being registered with CUCM below is the output of sh ccm-manager command. What could be the reason of that?
Router(config)#do sh ccm-m
MGCP Domain Name: Router
Priority Status Host
Primary Registering with CM 142.100.65.11
First Backup None
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 00:00:50 UTC May 18 2017 (elapsed time: 00:04:19)
Last MGCP traffic time: 00:04:40 UTC May 18 2017 (elapsed time: 00:00:29)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Configuration Auto-Download Information
Current version-id: 1495072874-6019cc1a-8fa9-4e5a-9c45-7ab828fe2e52
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 1
Download Successful : 1
Download Failed : 0
TFTP Download Failed : 0
Configuration Attempted : 1
Configuration Successful : 1
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: New Registration
FAX mode: disable
Configuration Error History:
Router(config)#
Router(config)#exi
BR
ABDULKARIM
05-17-2017 10:13 PM
Hi Abdul,
Please make sure that the Domain Name that you specify on CUCM page where you add the MGCP gateway is Router , if you make any changes then reset the gateway from cucm and do a no mgcp / mgcp on gateway. also share the complete config from VG.
Manish
05-18-2017 06:19 AM
Can you post your entire config? I am assuming you properly configured this getaway as MGCP on CUCM and configured ports accordingly?
