629
VGW MGCP - User hear busytone after 30 seconds when called (PSTN) is busy.
Hello All ,
i want to bring this matter to the discussion , i Hope it will Help .
In log file after 30 seconds, i find this error:
!!ERROR!! -ConnectionManager- wait_AuDisconnectRequest :CI NOT FOUND IN TABLE,CI(83186047,83186048),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)|4,100,56,1.9149709^192.168.102.101^CIPC-GL
In disconnect there is PI with inband information:
Sep 10 14:27:47.564: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x
805A
        Cause i = 0x8091 - User busy
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Sep 10 14:27:47.580: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x9A00
I have inserted in vgw configuration Disc_pi_off command but disabled the PI has not changed anything
Sep 11 13:13:06.743: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0001
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x0081, '0438668888'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0916477641'
Sep 11 13:13:06.823: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8001
Sep 11 13:13:12.287: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8001
        Cause i = 0x8A91 - User busy
Sep 11 13:13:42.215: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8001
Sep 11 13:13:42.239: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =0x0001
ULSS7-09-VGW01#u all
The option " Retain Media on Disconnect with PI for Active Call"  in services parameter is set to False
In attach my voice gateway configuration.
Thank in advance for your support,
Giovanna
0 REPLIES 0
Create
Recognize Your Peers
Content for Community-Ad
