VIC2-4FXO compatibility with C2921?
tiglath_simon
I am hoping someone can be of assistance, I was wondering if VIC2-4FXO is compatible with C2921 please? Some reference document say it is supported whilst other documentation say it not? My router is running PVDM3-32.
Thank you.
6 Replies 6
Tagir Temirgaliyev
I have it installed and working
2911router#sh inv
NAME: "CISCO2911/K9 chassis", DESCR: "CISCO2911/K9 chassis"
PID: CISCO2911/K9      , VID: V06 , SN: FC
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V04 , SN: FO
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation four port FXO voice interface daughtercard"
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64          , VID: V01 , SN: FO
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC       , VID: V04 , SN: DC
PLEASE POST ME THE FXO CONFIGURATION FOR CISCO 2911
Leonardo Santana
Yes it is
http://www.cisco.com/c/en/us/products/collateral/routers/2600-series-multiservice-platforms/product_data_sheet09186a00800921e7.html
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
naresh_bsf99
i am unable to make outgoing call VIC2-4FXO in cisco 2911 router by using PVDM3. Can any one resolve this issue
PID: CISCO2911/K9 , VID: V07 , SN: FGL170310J1
NAME: "WAN Interface Card - HWIC Serial 2T on Slot 0 SubSlot 0", DESCR: "WAN Interface Card - HWIC Serial 2T"
PID: HWIC-2T , VID: V04 , SN: FOC16415HXS
PID: VIC2-4FXO , VID: V04 , SN: FOC15317K28
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16 , VID: V01 , SN: FOC17062L3M
PID: PWR-2911-AC , VID: V05 , SN: QCS1648Z1TS
You will need to share the running config and debugs ( debug voice ccapi inout ) for the failed call to get assistance with failed call scenario.
Manish
- Do rate helpful posts -
Dear sir,
The running config of my router is as
User Access Verification
Password:
SAMBA>en
Password:
Password:
Router2911#sh run
Building configuration...
Current configuration : 5072 bytes
! No configuration change since last restart
version 15.1
hostname Router2911
boot-start-marker
boot-end-marker
enable secret 4 4rKoLW6d2Rb4sX774lcia77l3Av.N6X6fp2fWBQJbAc
enable password system!
no aaa new-model
no ipv6 cef
ip source-route
ip cef
voice-card 0
voice service voip
 no ip address trusted authenticate
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
license udi pid CISCO2911/K9 sn FGL170310J1
license boot module c2900 technology-package uck9
hw-module pvdm 0/0
redundancy
class-map match-any AutoQoS-VoIP-RTP-Trust
 match ip dscp ef
class-map match-all VIDEO
 description QOS for VIDEO Traffic
 match access-group 100
 match  precedence 3  4
class-map match-any AutoQoS-VoIP-Control-Trust
 match ip dscp cs3
 match ip dscp af31
policy-map AutoQoS-Policy-Trust
 class AutoQoS-VoIP-RTP-Trust
  priority percent 70
 class AutoQoS-VoIP-Control-Trust
  bandwidth percent 5
 class class-default
  fair-queue
policy-map MYQOS-POLICY
 class VIDEO
  bandwidth 32
  random-detect
  compress header ip rtp
 class class-default
  fair-queue
  random-detect
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 170.131.2.1 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0
 ip address 10.10.6.1 255.255.255.0
 encapsulation ppp
 ip ospf message-digest-key 1 md5 7 13272434342D2919
interface Serial0/0/1
 no ip address
 shutdown
 clock rate 2000000
router ospf 100
 area 2 authentication message-digest
 network 10.10.6.0 0.0.0.255 area 2
 network 170.131.2.0 0.0.0.255 area 2
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
control-plane
voice-port 0/1/0
 cptone IN
 timeouts call-disconnect 5
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp profile default
dspfarm profile 1 transcode
 shutdown
dial-peer voice 1 pots
 description call to samba
 destination-pattern 312
 port 0/1/0
 forward-digits 0
dial-peer voice 2 voip
 description call to FHQ
 destination-pattern 301
 session target ipv4:20.20.20.2
dial-peer voice 906 voip
dial-peer voice 9 voip
 description call to jmu
 destination-pattern 599
 session target ipv4:10.10.5.1
dial-peer voice 30 voip
 description call to KOL
 destination-pattern 239
 session target ipv4:10.10.54.1
dial-peer voice 31 voip
 description call to JOD
 destination-pattern 199
 session target ipv4:10.10.34.1
dial-peer voice 32 voip
 description call to Silchar 399
 destination-pattern 399
 session target ipv4:10.10.90.1
dial-peer voice 41 voip
 description call to Banglore 100
 destination-pattern 100
 session target ipv4:10.10.109.1
dial-peer voice 42 voip
 description call to Indore 600
 destination-pattern 600
 session target ipv4:10.10.106.1
dial-peer voice 25 voip
 description call to Srinagar 201
 destination-pattern 201
 session target ipv4:10.10.0.1
dial-peer voice 43 voip
 description call to RS Pura(110 Btn) 307
 destination-pattern 307
 session target ipv4:10.10.8.1
dial-peer voice 67 voip
 description call to Patgaon/Guhati
 destination-pattern 361
 session target ipv4:10.10.86.1
dial-peer voice 82 voip
 description call to ADG(W) 331
 destination-pattern 331
 session target ipv4:10.10.111.1
dial-peer voice 83 voip
 description call to Tekanpur 444
 destination-pattern 444
 session target ipv4:10.10.108.1
when i dial any extension number the voice summary shows
SAMBA#sh voice call summary
PORT CODEC VAD VTSP STATE VPM STATE
0/1/0 g711ulaw n S_WAIT_RELEASE_NC FXOLS_OFFHOOK
0/1/1 - - - FXOLS_ONHOOK
0/1/2 - - - FXOLS_ONHOOK
0/1/3 - - - FXOLS_ONHOOK
the calls disconnect imdtly
