VIC2-4FXS/DID in 3845 setup Guide
Shahab Salour
I am setting up a vic2-4FXO/DID in a 3845 router as a personnal experiance as below.
IOS is c3845-adventerprisek9-mz.151-4.M3
voice-port 0/1/0
signal loop-start
cptone us
ring frequency 25
no shutdown
voice-port 0/1/1
signal loop-start
cptone us
ring frequency 25
no shutdown
dial-peer voice 401 pots
desttination-pattern +14085553737
port 0/1/0
dial-peer voice 402 pots
desttination-pattern +14085554141
port 0/1/1
num-exp 3737 +1408555373
num-exp 4141 +14085554141
Scenario consists of 2 handsets which have to call each other by 3737 or 4141
everything seems to be fine.
except, when I dial the other number, i get a busy tone & 2ndd handset doesn't ring.
7 Replies 7
Aditya Gupta
Why do you want to plug handset(analog phones) in FXO ports ?
I am using FXS module.
One of your num-exp seams to be wrong, num-exp 3737 +1408555373
Change this to num-exp 3737 +14085553737
Please rate all useful posts.
Response Signature
Thank you Roger.
It was a mistyping. The router configuration is correct.
I see that a correct answer by Roger, made with the will to help, has been low-rated. That should never happen!
I've rated it again to partially compensate.
Thank you Paolo for the appreciation.
Response Signature
Dear Paolo,
Thanks to your special attention to the subject.
As I mentioned in my reply to Roger, I mistyped it in discussion, while it is correct in router configuration file.
Meanwhile, please help to solve the problem.
