the scenario is Central Office with CME 7 on a 2811. Remote office running 2811 with no voice code. PRI comes in at central site. Can I put a VIC2-2FXS card in the remote router and get calls working over to it from the central site? Fax machines are at the remote site and the preference is to not to have to upgrade routers at remote sites to run voice code.
Thanks in advance! replies rated
Solved! Go to Solution.
Sure, but you will also need PVDM module to support the VIC card.
HTH,
Chris
HTH,
Chris
Thanks Chris!
Can I get a high level explanation of how this woud work?
Replies rated
