10-19-2012 09:06 AM - edited 03-16-2019 01:47 PM
the scenario is Central Office with CME 7 on a 2811. Remote office running 2811 with no voice code. PRI comes in at central site. Can I put a VIC2-2FXS card in the remote router and get calls working over to it from the central site? Fax machines are at the remote site and the preference is to not to have to upgrade routers at remote sites to run voice code.
Thanks in advance! replies rated
Solved! Go to Solution.
10-19-2012 09:19 AM
Sure, but you will also need PVDM module to support the VIC card.
HTH,
Chris
10-19-2012 09:19 AM
HTH,
Chris
10-19-2012 09:24 AM
Thanks Chris!
12-05-2012 09:06 AM
Can I get a high level explanation of how this woud work?
Replies rated
