03-27-2020 02:57 AM
Hello Team,
My customer is migrating MGCP based PRI in Cisco 2901 VG to SIP ITSP type PSTN connectivity..
They also have mgcp controlled based analog phone connected to VIC3-2FXS/DID card..
i am not sure after migrating to SIP/CUBE like architecture, how analog phone will be register or work on these card.
Any support highly appreciate..
________________________
extract of my current VG configuration for analog port
dial-peer voice 99901990 pots
service mgcpapp
port 0/1/0
dial-peer voice 99901099 pots
service mgcpapp
port 0/1/0
i got the above link , but not able to see, whether VIC3-2FXS/DID card will support these particular configuration or not
Best Regards
Anil Singh
Solved! Go to Solution.
03-27-2020 08:21 AM
Any ISR can easily handle several protocols at the same time, you can have your SIP trunks and use MGCP/SCCP/H.323 as well. Each one is handled independently with their own configuration.
03-27-2020 06:04 AM
Recommend you to reconfigure the analogue ports to be SCCP controlled.
03-27-2020 08:21 AM
03-27-2020 08:39 AM
