vic3-4fxs/did
John Safarik
Beginner
Beginner
                   Is this card supported in a 2921 series (IOS Ver 15.0 M5) ?
Having issue to where you call a DID and get 30 seconds of dead air and then busy tone.
Verizon gets good wink signals and can process calls with test equipment at DMARC.
I have a cable guy coming out to verify connections, but this was working 100% in an Avaya before swinging to Cisco gateway.
They are configured as H323 trunks. I would normally think if this card is not supported, I would have trouble programming it due to errors, but not the case.
Thank you.
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Yes, it is.
Chris
Thank you!
Hi John,
Card is supported. you can refer link
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/aag_c07_563807.pdf
regds,
aman
paolo bevilacqua
Hall of Fame Master
Check config and "debug vpm signal".
Recognize Your Peers
