Highlighted
Beginner
Video/audio conference config cucm 8.5
Just want to know if this is possible on this appliance
and the way to go about
8 REPLIES 8
Advocate
You can have the basic adhoc
You can have the basic adhoc/meet-me for aduio conferencing and the basic two way video conferencing with video end points. If you want to look at anything higher than that you will need to look into something like CWMS etc.
-Terry
Advisor
Hi, Please refer the link
Please refer the link which says u need to have CUCM 8.6 or higher along with ISR G2
http://www.cisco.com/c/en/us/products/collateral/unified-communications/voice-video-conferencing-isr-routers/qa_c67-649850.html
regds,
aman
Beginner
I just want the basic video
I just want the basic video conferencing an and advanced ad hoc if possible too
Advocate
Basic Video calls are
Basic Video calls are possible with CUCM8.5 with one to one video call but not multi-party.
You will need to have at least CUCM 8.6 as per above post from Aman or have a conferencing solution.
-Terry
Beginner
Hello guys Am trying to do
Hello guys
Am trying to do call forwarding but is not going through nor normal conf
is there a particular conf i can activate
so that this works
Hall of Fame Cisco Employee
OK, let's go back one step,
OK, let's go back one step, what HW do you have to work with????
Audio conferences, you can do with the CUCM SW CFB, for video, you need dedicated resources, which you need to buy.
java
if this helps, please rate
Beginner
i got it serviceabilityand
i got it
serviceability
and under media resource
later make sure region is well configured
and i use system default for called on the pool which is then used to config the phones
Beginner
i got it
serviceability
Content for Community-Ad
July's Community Spotlight Awards
