Video/audio conference config cucm 8.5
divine007
Just want to know if this is possible on this appliance
and the way to go about
8 Replies 8
Terry Cheema
You can have the basic adhoc/meet-me for aduio conferencing and the basic two way video conferencing with video end points. If you want to look at anything higher than that you will need to look into something like CWMS etc.
-Terry
Please refer the link which says u need to have CUCM 8.6 or higher along with ISR G2
http://www.cisco.com/c/en/us/products/collateral/unified-communications/voice-video-conferencing-isr-routers/qa_c67-649850.html
regds,
aman
I just want the basic video conferencing an and advanced ad hoc if possible too
Basic Video calls are possible with CUCM8.5 with one to one video call but not multi-party.
You will need to have at least CUCM 8.6 as per above post from Aman or have a conferencing solution.
-Terry
Hello guys
Am trying to do call forwarding but is not going through nor normal conf
is there a particular conf i can activate
so that this works
OK, let's go back one step, what HW do you have to work with????
Audio conferences, you can do with the CUCM SW CFB, for video, you need dedicated resources, which you need to buy.
java
if this helps, please rate
i got it
serviceability
and under media resource
later make sure region is well configured
and i use system default for called on the pool which is then used to config the phones
i got it
serviceability
