03-14-2013 12:13 AM - edited 03-16-2019 04:15 PM
Hello everybody,
I've got a problem on Video Call through Site-to-Site VPN
Here is the environment
Local Site
CUCM8.6
Remote site
IP phone 8961
IP phone 9951 with Camera
I have established a Site-to-Site VPN on local site's ASA and connected to remote site's router
all IP phones are able to registered to CUCM remotely, and make calls successful
However, for the camera on 9951, it cannot show/transfer the video to 8961
* I'm sure the camera with 9951 are working fine, because it has been plugged to another CUCM cluster and well tested.
Anybody knows... is there anythings i should check with? or missing configuration?
Thanks for the advance
Sam
Solved! Go to Solution.
03-17-2013 02:40 AM
Are you blocking UDP ports, I use the below links for tandberg. Try one of them, hoping one of them help you
http://www.videocentric.co.uk/support/firewall-config/tandberg-firewall-config.shtml
http://vtctalk.com/forum/showthread.php?t=43920
Anas
please rate if it is helpful
03-17-2013 02:40 AM
Anas
