video calls (Cisco ip phones 8865)not working on cisco 4331
Bothra Group
Dear Team,
Unable to make video calls from cisco IP phones (8865) on cisco VG 4331. Voice calls are working fine.
6 Replies 6
When you say you have a VG 4331 do you mean that you are using CUCM Express? What is your configuration under voice register global and for that phone's voice register pool?
Is the issue between two 8865 phones or from the 8865 to another model (and what is that)?
Essentially, we need a lot more detail of your issue in order to help.
Maren
Dear Maren,
We are using CUCM express and below is the voice register global config:
Im trying between two 8865 phones only.
mode cme
source-address 172.17.40.8 port 5600
bandwidth video tias-modifier 512000 negotiate end-to-end
max-dn 200
max-pool 10
0 timezone 39 date-format D/M/Y
create profile sync 001514457146034A
camera
video
auto-register ! !
First, I apologize that I asked for your config. I didn't see that you had attached it to your original post.
What happens with the video call between the 8865 phones if you remove the "codec g711ulaw" command from the 8865's voice register pools? (And 'create profile' after of course.) When I've configured CME video in the past I either leave off the manual codec command or I add a voice class codec list that includes video codecs.
A 'debug ccsip messages' that includes the message exchange for the 8865-8865 call would reveal if video is being negotiated at all, and if so which part of the system is declining to select video. Can you run that and attach it to a post?
Maren
Dear Maren,
I have removed codec from voice register pools ( Ext no 185, 186) but no luck.
VTZ_ISR_4331#show log
Syslog logging: enabled (0 messages dropped, 5 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 1181282 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 1612 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 1181284 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 1465 message lines logged
Logging Source-Interface: VRF Name:
TLS Profiles:
Log Buffer (102400 bytes):
Sep 12 04:55:27.239: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:165@ap.ims.airtel.in SIP/2.0
Via: SIP/2.0/UDP 172.17.40.141:5060;branch=z9hG4bK2a33d1a3
From: "RK" <sip:188@172.17.40.8>;tag=3891b747f1d819b75feef016-65bf1733
To: <sip:165@ap.ims.airtel.in>
Call-ID: 3891b747-f1d8002e-436ec59b-02688258@172.17.40.141
Max-Forwards: 70
Session-ID: 674da60800105000a0003891b747f1d8;remote=3df6fe4000105000a0003891b747f1f3
Date: Thu, 12 Sep 2024 04:55:28 GMT
CSeq: 101 CANCEL
User-Agent: Cisco-CP7841/14.0.1
Content-Length: 0
Sep 12 04:55:27.242: //710034/0EC0ABC3B198/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 12 Sep 2024 04:55:27 GMT
CSeq: 101 CANCEL
Session-ID: 3df6fe4000105000a0003891b747f1f3;remote=674da60800105000a0003891b747f1d8
Content-Length: 0
Sep 12 04:55:27.243: //710035/0EC0ABC3B198/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:165@172.17.40.99:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.40.8:5060;branch=z9hG4bK6AB5530
From: "RK" <sip:188@ap.ims.airtel.in>;tag=767C8AFD-1B94
To: <sip:165@172.17.40.99>
Date: Thu, 12 Sep 2024 04:55:25 GMT
Call-ID: EC20B69-6FFA11EF-B19E80F5-5326CA70@ap.ims.airtel.in
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1726116927
Reason: Q.850;cause=16
Session-ID: 674da60800105000a0003891b747f1d8;remote=00000000000000000000000000000000
Content-Length: 0
Sep 12 04:55:27.243: //710034/0EC0ABC3B198/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 487 Request Cancelled
To: <sip:165@ap.ims.airtel.in>;tag=767C8B9D-C03
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-17.6.1a
Content-Length: 0
Sep 12 04:55:27.251: //710035/0EC0ABC3B198/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <sip:165@172.17.40.99>;tag=3891b747f1f345f13e895b96-0f939fa2
Date: Thu, 12 Sep 2024 04:55:29 GMT
CSeq: 101 CANCEL
Server: Cisco-CP7841/14.0.1
Content-Length: 0
Sep 12 04:55:27.257: //710035/0EC0ABC3B198/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Contact: <sip:1E1A6-6D7@172.17.40.99:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP3891B747F1F3"
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "Admin" <sip:165@172.17.40.8>;party=called;id-type=subscriber;privacy=off;screen=yes
Allow-Events: kpml,dialog
Content-Length: 0
Sep 12 04:55:27.258: //710035/0EC0ABC3B198/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x7FD0CEB41360
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 188
Called Number : 165
Source IP Address (Sig 172.17.40.8
Destn SIP Req Addr:Port : 172.17.40.99:5060
Destn SIP Resp Addr:Port : 172.17.40.99:5060
Destination Name : 172.17.40.99
Sep 12 04:55:27.258: //710035/0EC0ABC3B198/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 172.17.40.8
Source IP Port (Media): 28590
Destn IP Address (Media): -
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC) : 16
Disconnect Cause (SIP) : 487
Sep 12 04:55:27.258: //710035/0EC0ABC3B198/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:165@172.17.40.99:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sep 12 04:55:27.267: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:165@ap.ims.airtel.in SIP/2.0
Session-ID: 735e933a00105000a0003891b747f1d8;remote=674da60800105000a0003891b747f1d8
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sep 12 04:55:27.268: //710034/0EC0ABC3B198/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7FD0CEC1B470
Called Number : 165
Destn SIP Req Addr:Port : 172.17.40.141:5060
Destn SIP Resp Addr:Port : 172.17.40.141:5060
Destination Name : 172.17.40.141
Sep 12 04:55:27.268: //710034/0EC0ABC3B198/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Negotiated Codec : g711ulaw
Negotiated Codec Bytes : 160
Nego. Codec payload : 0 (tx), 0 (rx)
Source IP Port (Media): 28588
Destn IP Address (Media): 172.17.40.141
Destn IP Port (Media): 24014
Sep 12 04:55:33.762: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:172.17.40.8 SIP/2.0
Via: SIP/2.0/UDP 172.17.40.149:5060;branch=z9hG4bK79b381ee
From: <sip:145@172.17.40.8>;tag=3891b747f1c31e845ed2a86d-24872832
To: <sip:145@172.17.40.8>
Call-ID: 3891b747-f1c30059-0b369870-2b15520c@172.17.40.149
Max-Forwards: 70
Session-ID: 545aacc400105000a0003891b747f1c3;remote=00000000000000000000000000000000
Date: Thu, 12 Sep 2024 04:55:37 GMT
CSeq: 7584 REGISTER
Contact: <sip:1E157-10CD@172.17.40.149:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-3891b747f1c3>";+u.sip!devicename.ccm.cisco.com="SEP3891B747F1C3";+u.sip!model.ccm.cisco.com="622"
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Content-Length: 0
Expires: 3600
Sep 12 04:55:33.764: //710036/13DE5454B19F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:145@172.17.40.8>;tag=767CAC7B-2480
Date: Thu, 12 Sep 2024 04:55:33 GMT
CSeq: 7584 REGISTER
Supported: X-cisco-cme-sis-9.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:145@172.17.40.149:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:55:33.977: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.103:5060;branch=z9hG4bK53839416
From: <sip:148@172.17.40.8>;tag=8c1e809a24664648431adba0-6f269851
To: <sip:148@172.17.40.8>
Call-ID: 8c1e809a-2466016f-55489487-6ffa8177@172.17.40.103
Max-Forwards: 70
Session-ID: 2f2c9b3f00105000a0008c1e809a2466;remote=00000000000000000000000000000000
Date: Thu, 12 Sep 2024 04:55:39 GMT
CSeq: 17383 REGISTER
Contact: <sip:1E16B-110@172.17.40.103:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-8c1e809a2466>";+u.sip!devicename.ccm.cisco.com="SEP8C1E809A2466";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:55:33.979: //710037/13FF2230B1A0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:148@172.17.40.8>;tag=767CAD52-19F7
Contact: <sip:148@172.17.40.103:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:55:35.711: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.101:5060;branch=z9hG4bK624ab75b
From: <sip:135@172.17.40.8>;tag=3891b747f1f2440761edb655-466cf346
To: <sip:135@172.17.40.8>
Call-ID: 3891b747-f1f20032-26f6c1c9-40c3078a@172.17.40.101
Max-Forwards: 70
Session-ID: 7b92598700105000a0003891b747f1f2;remote=00000000000000000000000000000000
Date: Thu, 12 Sep 2024 04:55:36 GMT
Contact: <sip:1E12C-11ED@172.17.40.101:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-3891b747f1f2>";+u.sip!devicename.ccm.cisco.com="SEP3891B747F1F2";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:55:35.713: //710038/1507B971B1A1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:135@172.17.40.8>;tag=767CB418-D57
Date: Thu, 12 Sep 2024 04:55:35 GMT
Contact: <sip:135@172.17.40.101:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:55:36.046: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.118:5060;branch=z9hG4bK53324e78
From: <sip:141@172.17.40.8>;tag=8c1e809a253f42f348aa9366-061312db
To: <sip:141@172.17.40.8>
Call-ID: 8c1e809a-253f0043-6d127353-4bd6f3e5@172.17.40.118
Max-Forwards: 70
Session-ID: ad4bb59c00105000a0008c1e809a253f;remote=00000000000000000000000000000000
Date: Thu, 12 Sep 2024 04:55:38 GMT
CSeq: 17086 REGISTER
User-Agent: Cisco-CP7841/14.1.1
Contact: <sip:135D590-5D8@172.17.40.118:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-8c1e809a253f>";+u.sip!devicename.ccm.cisco.com="SEP8C1E809A253F";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:55:36.048: //710039/153AD864B1A2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:141@172.17.40.8>;tag=767CB567-252E
Contact: <sip:141@172.17.40.118:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:55:39.952: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.99:5060;branch=z9hG4bK511c84f1
From: <sip:165@172.17.40.8>;tag=3891b747f1f345f3558ca330-2b4e23be
To: <sip:165@172.17.40.8>
Call-ID: 3891b747-f1f30115-014a9557-44fee517@172.17.40.99
Max-Forwards: 70
Session-ID: a3ad8c7e00105000a0003891b747f1f3;remote=00000000000000000000000000000000
Date: Thu, 12 Sep 2024 04:55:42 GMT
CSeq: 17391 REGISTER
Contact: <sip:1E1A6-6D7@172.17.40.99:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-3891b747f1f3>";+u.sip!devicename.ccm.cisco.com="SEP3891B747F1F3";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Authorization: Digest username="Ipphone165",realm="",uri="sip:172.17.40.8",response="55fb40f46967bd74725935528174b907",nonce="82C8A5350B79BDF3",cnonce="78526a6b",qop=auth,nc=00000236,algorithm=MD5
Sep 12 04:55:39.955: //710040/178EFFA7B1A3/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:165@172.17.40.8>;tag=767CC4A9-1108
Contact: <sip:165@172.17.40.99:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:55:53.785: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.74:5060;branch=z9hG4bK15d3b318
From: <sip:130@172.17.40.8>;tag=8c1e809a23f302e52f5b52de-0746b224
To: <sip:130@172.17.40.8>
Call-ID: 8c1e809a-23f30002-285f31fe-39362148@172.17.40.74
Max-Forwards: 70
Session-ID: 17d2978500105000a0008c1e809a23f3;remote=00000000000000000000000000000000
Date: Thu, 12 Sep 2024 04:55:54 GMT
CSeq: 835 REGISTER
Contact: <sip:2F4E93F8-47D@172.17.40.74:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-8c1e809a23f3>";+u.sip!devicename.ccm.cisco.com="SEP8C1E809A23F3";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:55:53.787: //710041/1FCDBFDCB1A4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:130@172.17.40.8>;tag=767CFAB2-DA6
Date: Thu, 12 Sep 2024 04:55:53 GMT
CSeq: 835 REGISTER
Contact: <sip:130@172.17.40.74:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:55:54.448: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.214:5060;branch=z9hG4bK1a6f361e
From: <sip:186@172.17.40.8>;tag=08cca7855c3e001d5e470fce-206d10a9
To: <sip:186@172.17.40.8>
Call-ID: 08cca785-5c3e0003-06b38e92-07f37ea6@172.17.40.214
Max-Forwards: 70
Session-ID: a630162600105000a00008cca7855c3e;remote=00000000000000000000000000000000
CSeq: 110 REGISTER
User-Agent: Cisco-CP8865/14.1.1
Contact: <sip:4EA8C63B-270C@172.17.40.214:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-08cca7855c3e>";+u.sip!devicename.ccm.cisco.com="SEP08CCA7855C3E";+u.sip!model.ccm.cisco.com="36225";video
Content-Length: 0
Expires: 3600
Sep 12 04:55:54.450: //710042/2032C404B1A5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:186@172.17.40.8>;tag=767CFD49-F91
CSeq: 110 REGISTER
Contact: <sip:186@172.17.40.214:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:55:55.362: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:185@172.17.40.8;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.17.40.214:5060;branch=z9hG4bK7cd9fa43
From: "V C Bothra" <sip:186@172.17.40.8>;tag=08cca7855c3e001e14b7aa9b-71667fd6
To: <sip:185@172.17.40.8>
Call-ID: 08cca785-5c3e0006-527c786a-1392857e@172.17.40.214
Max-Forwards: 70
Session-ID: 660a624a00105000a00008cca7855c3e;remote=00000000000000000000000000000000
CSeq: 101 INVITE
Contact: <sip:4EA8C63B-270C@172.17.40.214:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP08CCA7855C3E";video
Expires: 180
Accept: application/sdp
Remote-Party-ID: "V C Bothra" <sip:186@172.17.40.8>;party=calling;id-type=subscriber;privacy=off;screen=yes
Recv-Info: conference
Recv-Info: x-cisco-conference
Content-Length: 1175
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 6129 0 IN IP4 172.17.40.214
s=SIP Call
b=AS:4064
t=0 0
m=audio 20672 RTP/AVP 0 8 116 18 101
c=IN IP4 172.17.40.214
b=TIAS:64000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
m=video 32298 RTP/AVP 100 126 97
b=TIAS:4000000
a=rtpmap:100 H264/90000
a=fmtp:100 profile-level-id=640C16;packetization-mode=1;level-asymmetry-allowed=1;max-mbps=108000;max-fs=3600;max-rcmd-nalu-size=256000
a=imageattr:* recv [x=800,y=480,q=0.60] [x=1280,y=720,q=0.50]
a=rtpmap:126 H264/90000
a=fmtp:126 profile-level-id=428016;packetization-mode=1;level-asymmetry-allowed=1;max-mbps=108000;max-fs=3600;max-rcmd-nalu-size=256000
a=rtpmap:97 H264/90000
a=fmtp:97 profile-level-id=428016;packetization-mode=0;level-asymmetry-allowed=1;max-mbps=108000;max-fs=3600;max-rcmd-nalu-size=256000
a=rtcp-fb:* nack pli
a=rtcp-fb:* ccm fir
a=rtcp-fb:* ccm tmmbr
a=sendrecv
Sep 12 04:55:55.368: //710043/20BE621DB1A6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 12 Sep 2024 04:55:55 GMT
CSeq: 101 INVITE
Session-ID: 00000000000000000000000000000000;remote=660a624a00105000a00008cca7855c3e
Content-Length: 0
Sep 12 04:55:55.374: //710045/20BE621DB1A6/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:185@172.17.40.212:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.40.8:5060;branch=z9hG4bK6AB61415
Remote-Party-ID: "V C Bothra" <sip:186@ap.ims.airtel.in>;party=calling;screen=yes;privacy=off
From: "V C Bothra" <sip:186@ap.ims.airtel.in>;tag=767D00E5-EEE
To: <sip:185@172.17.40.212>
Call-ID: 20BFC1C3-6FFA11EF-B1AC80F5-5326CA70@ap.ims.airtel.in
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 0549347869-1878659567-2980479221-1395051120
User-Agent: Cisco-SIPGateway/IOS-17.6.1a
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1726116955
Contact: <sip:186@172.17.40.8:5060>
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 352
v=0
o=CiscoSystemsSIP-GW-UserAgent 9022 3737 IN IP4 172.17.40.8
s=SIP Call
c=IN IP4 172.17.40.8
t=0 0
m=audio 28594 RTP/AVP 18 121 19
a=fmtp:18 annexb=no
a=rtpmap:121 frf-dialed-digit/8000
a=fmtp:121 0-15
a=rtpmap:19 CN/8000
a=ptime:20
m=video 0 RTP/AVP 255
b=TIAS:512000
Sep 12 04:55:55.379: //710045/20BE621DB1A6/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Session-ID: 54d24a9000105000a00008cca7855c2c;remote=660a624a00105000a00008cca7855c3e
CSeq: 101 INVITE
Server: Cisco-CP8865/14.1.1
Contact: <sip:4E82BF8E-1809@172.17.40.212:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP08CCA7855C2C";video
Content-Length: 0
Sep 12 04:55:55.429: //710045/20BE621DB1A6/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:185@172.17.40.212>;tag=08cca7855c2c00101cd13629-77a1b25b
CSeq: 101 INVITE
Remote-Party-ID: "Hari - Gaurav" <sip:185@172.17.40.8>;party=called;id-type=subscriber;privacy=off;screen=yes
Content-Length: 0
Sep 12 04:55:55.431: //710043/20BE621DB1A6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:185@172.17.40.8>;tag=767D011F-10EE
CSeq: 101 INVITE
Remote-Party-ID: "Hari - Gaurav" <sip:185@ap.ims.airtel.in>;party=called;screen=yes;privacy=off
Contact: <sip:4E82BF8E-1809@172.17.40.8:5060>
Content-Length: 0
Sep 12 04:55:56.910: //710045/20BE621DB1A6/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Thu, 12 Sep 2024 04:55:56 GMT
CSeq: 101 INVITE
Content-Length: 228
v=0
o=Cisco-SIPUA 4235 0 IN IP4 172.17.40.212
s=SIP Call
t=0 0
m=audio 22670 RTP/AVP 18
c=IN IP4 172.17.40.212
b=TIAS:64000
a=fmtp:18 annexb=no
a=sendrecv
c=IN IP4 0.0.0.0
Sep 12 04:55:56.912: //710045/20BE621DB1A6/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7FD0CEBE6A40
State of The Call : STATE_ACTIVE
Calling Number : 186
Called Number : 185
Destn SIP Req Addr:Port : 172.17.40.212:5060
Destn SIP Resp Addr:Port : 172.17.40.212:5060
Destination Name : 172.17.40.212
Sep 12 04:55:56.912: //710045/20BE621DB1A6/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 2
Media Stream : 1
Negotiated Codec : g729r8
Negotiated Codec Bytes : 20
Nego. Codec payload : 18 (tx), 18 (rx)
Source IP Port (Media): 28594
Destn IP Address (Media): 172.17.40.212
Destn IP Port (Media): 22670
Media Stream : 2
Source IP Port (Media): 0
Destn IP Address (Media): 0.0.0.0
Sep 12 04:55:56.913: //710045/20BE621DB1A6/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4E82BF8E-1809@172.17.40.212:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.17.40.8:5060;branch=z9hG4bK6AB7B01
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: 660a624a00105000a00008cca7855c3e;remote=54d24a9000105000a00008cca7855c2c
Content-Length: 0
Sep 12 04:55:56.918: //710043/20BE621DB1A6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Contact: <sip:185@172.17.40.8:5060>
Supported: replaces
Supported: timer
Content-Length: 271
v=0
o=CiscoSystemsSIP-GW-UserAgent 2958 5804 IN IP4 172.17.40.8
s=SIP Call
t=0 0
m=audio 28592 RTP/AVP 18
a=fmtp:18 annexb=no
a=ptime:20
m=video 0 RTP/AVP 100
b=TIAS:512000
Sep 12 04:55:56.927: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:185@172.17.40.8:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.40.214:5060;branch=z9hG4bK7f773c09
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sep 12 04:55:56.928: //710043/20BE621DB1A6/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7FD0CEBD79A0
Called Number : 185
Destn SIP Req Addr:Port : 172.17.40.214:5060
Destn SIP Resp Addr:Port : 172.17.40.214:5060
Destination Name : 172.17.40.214
Sep 12 04:55:56.928: //710043/20BE621DB1A6/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 28592
Destn IP Address (Media): 172.17.40.214
Destn IP Port (Media): 20672
Media Stream : 2
Negotiated Codec : h264
Nego. Codec payload : 97 (tx), 119 (rx)
Sep 12 04:56:03.339: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:172.17.40.8:5060 SIP/2.0
Via: SIP/2.0/TCP 172.17.27.59:5060;branch=z9hG4bKa4a448bb826
To: <sip:172.17.40.8>
Date: Thu, 12 Sep 2024 04:56:03 GMT
Call-ID: 4e7d7900-1f018ec6-9b80-3b1b11ac@172.17.27.59
User-Agent: Cisco-CUCM14.0
CSeq: 101 OPTIONS
Contact: <sip:172.17.27.59:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
Sep 12 04:56:03.341: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:172.17.40.8>;tag=767D2004-1F
CSeq: 101 OPTIONS
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Length: 372
v=0
o=CiscoSystemsSIP-GW-UserAgent 2653 801 IN IP4 172.49.53.22
s=SIP Call
c=IN IP4 172.49.53.22
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
Sep 12 04:56:05.006: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:185@172.17.40.8:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.40.214:5060;branch=z9hG4bK0c676b21
Max-Forwards: 70
Date: Thu, 12 Sep 2024 04:56:04 GMT
CSeq: 102 BYE
Content-Length: 0
Sep 12 04:56:05.009: //710043/20BE621DB1A6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 12 Sep 2024 04:56:05 GMT
CSeq: 102 BYE
Content-Length: 0
Sep 12 04:56:05.010: //710045/20BE621DB1A6/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:4E82BF8E-1809@172.17.40.212:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.17.40.8:5060;branch=z9hG4bK6AB81DCA
Max-Forwards: 70
Timestamp: 1726116965
CSeq: 102 BYE
Content-Length: 0
Sep 12 04:56:05.011: //710043/20BE621DB1A6/SIP/Call/sipSPICallInfo:
Called Number : 185
Sep 12 04:56:05.012: //710043/20BE621DB1A6/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Media Stream : 2
Sep 12 04:56:05.012: //710043/20BE621DB1A6/SIP/Call/sipSPICallInfo:
Disconnect Cause (SIP) : 200
Sep 12 04:56:05.136: //710045/20BE621DB1A6/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
Sep 12 04:56:05.136: //710045/20BE621DB1A6/SIP/Call/sipSPICallInfo:
Called Number : 185
Sep 12 04:56:05.136: //710045/20BE621DB1A6/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Media Stream : 2
Sep 12 04:56:05.137: //710045/20BE621DB1A6/SIP/Call/sipSPICallInfo:
Sep 12 04:56:05.425: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.109:5060;branch=z9hG4bK1df1dc51
From: <sip:168@172.17.40.8>;tag=3891b747f202467042a9cd2e-73c8c1a3
To: <sip:168@172.17.40.8>
Call-ID: 3891b747-f2020112-6e666f41-650a3382@172.17.40.109
Max-Forwards: 70
Session-ID: 5e417c5d00105000a0003891b747f202;remote=00000000000000000000000000000000
Date: Thu, 12 Sep 2024 04:56:09 GMT
CSeq: 17385 REGISTER
Contact: <sip:1E1B0-15C5@172.17.40.109:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-3891b747f202>";+u.sip!devicename.ccm.cisco.com="SEP3891B747F202";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:56:05.427: //710048/26BDB8BAB1AE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:168@172.17.40.8>;tag=767D282A-1B5F
Contact: <sip:168@172.17.40.109:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:56:06.194: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK7cdabe4e
From: <sip:152@172.17.40.8>;tag=8c1e809a252b3ba7070ccc68-4dfdd85e
To: <sip:152@172.17.40.8>
Call-ID: 8c1e809a-252b00aa-618afe3f-5a3b9821@172.17.40.137
Max-Forwards: 70
Session-ID: 5f1c51c700105000a0008c1e809a252b;remote=00000000000000000000000000000000
Date: Thu, 12 Sep 2024 04:56:11 GMT
CSeq: 14889 REGISTER
Contact: <sip:1E188-DD9@172.17.40.137:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-8c1e809a252b>";+u.sip!devicename.ccm.cisco.com="SEP8C1E809A252B";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:56:06.195: //710049/27331025B1AF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:152@172.17.40.8>;tag=767D2B2B-26BE
Date: Thu, 12 Sep 2024 04:56:06 GMT
Contact: <sip:152@172.17.40.137:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:56:06.705: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.114:5060;branch=z9hG4bK02f5d52a
From: <sip:149@172.17.40.8>;tag=3891b747f0544471635a5bf9-4861ee8e
To: <sip:149@172.17.40.8>
Call-ID: 3891b747-f0540062-5b100abd-259a51dc@172.17.40.114
Max-Forwards: 70
Session-ID: 4076b42900105000a0003891b747f054;remote=00000000000000000000000000000000
Date: Thu, 12 Sep 2024 04:56:08 GMT
CSeq: 17384 REGISTER
Contact: <sip:1E172-374@172.17.40.114:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-3891b747f054>";+u.sip!devicename.ccm.cisco.com="SEP3891B747F054";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:56:06.707: //710050/2781081DB1B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:149@172.17.40.8>;tag=767D2D2A-1BD7
Contact: <sip:149@172.17.40.114:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:56:07.504: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.112:5060;branch=z9hG4bK1039ea2f
From: <sip:131@172.17.40.8>;tag=8c1e809a257e44fa5cae46d7-68d2590d
To: <sip:131@172.17.40.8>
Call-ID: 8c1e809a-257e008b-15bd42dd-4c4ca2bf@172.17.40.112
Max-Forwards: 70
Session-ID: 90f08c2000105000a0008c1e809a257e;remote=00000000000000000000000000000000
Date: Thu, 12 Sep 2024 04:56:12 GMT
Contact: <sip:1E105-9E6@172.17.40.112:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-8c1e809a257e>";+u.sip!devicename.ccm.cisco.com="SEP8C1E809A257E";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:56:07.506: //710051/27FAF3E5B1B1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:131@172.17.40.8>;tag=767D3049-14F
Date: Thu, 12 Sep 2024 04:56:07 GMT
Contact: <sip:131@172.17.40.112:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:56:07.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.105:5060;branch=z9hG4bK652dc7bb
From: <sip:114@172.17.40.8>;tag=8c1e809a24f0452f4061a838-24f21413
To: <sip:114@172.17.40.8>
Call-ID: 8c1e809a-24f000a4-408e0bb3-44537ec5@172.17.40.105
Max-Forwards: 70
Session-ID: e6601d4800105000a0008c1e809a24f0;remote=00000000000000000000000000000000
Contact: <sip:1E0D0-FB5@172.17.40.105:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-8c1e809a24f0>";+u.sip!devicename.ccm.cisco.com="SEP8C1E809A24F0";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:56:07.898: //710052/2836C389B1B2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:114@172.17.40.8>;tag=767D31D1-BD4
Contact: <sip:114@172.17.40.105:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:56:07.939: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.107:5060;branch=z9hG4bK45c874b8
From: <sip:144@172.17.40.8>;tag=8c1e809a250543d23f4a63c7-76afaa80
To: <sip:144@172.17.40.8>
Call-ID: 8c1e809a-2505001a-7ab6c4da-4fd01408@172.17.40.107
Max-Forwards: 70
Session-ID: 8b79275700105000a0008c1e809a2505;remote=00000000000000000000000000000000
Date: Thu, 12 Sep 2024 04:56:15 GMT
Contact: <sip:1E14A-A02@172.17.40.107:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-8c1e809a2505>";+u.sip!devicename.ccm.cisco.com="SEP8C1E809A2505";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:56:07.941: //710053/283D531CB1B3/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:144@172.17.40.8>;tag=767D31FC-202B
Contact: <sip:144@172.17.40.107:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:56:07.942: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.106:5060;branch=z9hG4bK41860b4e
From: <sip:140@172.17.40.8>;tag=3891b747f1db43cf27ce239f-2481423c
To: <sip:140@172.17.40.8>
Call-ID: 3891b747-f1db0025-2a684067-02c263e8@172.17.40.106
Max-Forwards: 70
Session-ID: c2a2116700105000a0003891b747f1db;remote=00000000000000000000000000000000
Contact: <sip:1E07E-17AB@172.17.40.106:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-3891b747f1db>";+u.sip!devicename.ccm.cisco.com="SEP3891B747F1DB";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:56:07.944: //710054/283DC7EDB1B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:140@172.17.40.8>;tag=767D31FF-10FB
Contact: <sip:140@172.17.40.106:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:56:08.155: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.148:5060;branch=z9hG4bK25ac74b0
From: <sip:105@172.17.40.8>;tag=3891b747f057298c557b6845-19c03383
To: <sip:105@172.17.40.8>
Call-ID: 3891b747-f0570035-787e1d5c-5850e6bd@172.17.40.148
Max-Forwards: 70
Session-ID: 3bf3e70e00105000a0003891b747f057;remote=00000000000000000000000000000000
CSeq: 10609 REGISTER
Contact: <sip:2E6E0785-92F@172.17.40.148:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-3891b747f057>";+u.sip!devicename.ccm.cisco.com="SEP3891B747F057";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:56:08.157: //710055/285E7111B1B5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:105@172.17.40.8>;tag=767D32D4-49A
Contact: <sip:105@172.17.40.148:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:56:08.559: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.111:5060;branch=z9hG4bK2ee5c1b7
From: <sip:143@172.17.40.8>;tag=3891b747f1bd43fb0589a812-68df92e1
To: <sip:143@172.17.40.8>
Call-ID: 3891b747-f1bd0034-0f2252e6-3fd3abcb@172.17.40.111
Max-Forwards: 70
Session-ID: 8150f2fc00105000a0003891b747f1bd;remote=00000000000000000000000000000000
Date: Thu, 12 Sep 2024 04:56:16 GMT
Contact: <sip:1E143-10CE@172.17.40.111:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-3891b747f1bd>";+u.sip!devicename.ccm.cisco.com="SEP3891B747F1BD";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:56:08.561: //710056/289C15C6B1B6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:143@172.17.40.8>;tag=767D3468-140D
Contact: <sip:143@172.17.40.111:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:56:08.717: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.113:5060;branch=z9hG4bK7a3631d5
From: <sip:113@172.17.40.8>;tag=8c1e809a2536445d0a27a4dd-0b5b8806
To: <sip:113@172.17.40.8>
Call-ID: 8c1e809a-2536006b-5b54212f-36bff1db@172.17.40.113
Max-Forwards: 70
Session-ID: 83e41bdb00105000a0008c1e809a2536;remote=00000000000000000000000000000000
Contact: <sip:1E0C7-BE@172.17.40.113:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-8c1e809a2536>";+u.sip!devicename.ccm.cisco.com="SEP8C1E809A2536";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:56:08.719: //710057/28B40A2DB1B7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:113@172.17.40.8>;tag=767D3506-4FD
Contact: <sip:113@172.17.40.113:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:56:09.548: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.108:5060;branch=z9hG4bK67b52324
From: <sip:132@172.17.40.8>;tag=3891b747f00f449f08002495-60ac980d
To: <sip:132@172.17.40.8>
Call-ID: 3891b747-f00f009b-6102a9f2-5d221917@172.17.40.108
Max-Forwards: 70
Session-ID: 5c1f263800105000a0003891b747f00f;remote=00000000000000000000000000000000
Contact: <sip:1E10D-F05@172.17.40.108:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-3891b747f00f>";+u.sip!devicename.ccm.cisco.com="SEP3891B747F00F";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:56:09.550: //710058/2932FE8BB1B8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:132@172.17.40.8>;tag=767D3845-AAF
Contact: <sip:132@172.17.40.108:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:56:09.826: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.135:5060;branch=z9hG4bK106bbc2e
From: <sip:187@172.17.40.8>;tag=3891b747f314262a5e3bdd34-6e4307d1
To: <sip:187@172.17.40.8>
Call-ID: 3891b747-f3140056-7d633256-75d62f5d@172.17.40.135
Max-Forwards: 70
Session-ID: dc2d4e8a00105000a0003891b747f314;remote=00000000000000000000000000000000
Date: Thu, 12 Sep 2024 04:56:14 GMT
CSeq: 9611 REGISTER
Contact: <sip:34334DF4-1C4@172.17.40.135:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-3891b747f314>";+u.sip!devicename.ccm.cisco.com="SEP3891B747F314";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:56:09.828: //710059/295D4204B1B9/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:187@172.17.40.8>;tag=767D395B-E4F
CSeq: 9611 REGISTER
Contact: <sip:187@172.17.40.135:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:56:10.137: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.144:5060;branch=z9hG4bK02d525bd
From: <sip:142@172.17.40.8>;tag=8c1e809a25321e0b5d73a009-60f64b76
To: <sip:142@172.17.40.8>
Call-ID: 8c1e809a-25320043-6c649c4f-2027fc84@172.17.40.144
Max-Forwards: 70
Session-ID: c29b07d800105000a0008c1e809a2532;remote=00000000000000000000000000000000
Date: Thu, 12 Sep 2024 04:56:10 GMT
CSeq: 7604 REGISTER
Contact: <sip:1E0A2-1577@172.17.40.144:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-8c1e809a2532>";+u.sip!devicename.ccm.cisco.com="SEP8C1E809A2532";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:56:10.139: //710060/298CDEC4B1BA/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:142@172.17.40.8>;tag=767D3A92-24F4
CSeq: 7604 REGISTER
Contact: <sip:142@172.17.40.144:5060>;expires=120
Expires: 120
Content-Length: 0
Sep 12 04:56:10.149: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.141:5060;branch=z9hG4bK351ad71d
From: <sip:188@172.17.40.8>;tag=3891b747f1d819b947c8e9b6-577c9fc5
To: <sip:188@172.17.40.8>
Call-ID: 3891b747-f1d80016-20d82649-270f7ddd@172.17.40.141
Max-Forwards: 70
Session-ID: 735e933a00105000a0003891b747f1d8;remote=00000000000000000000000000000000
CSeq: 6588 REGISTER
Contact: <sip:1E0A9-2128@172.17.40.141:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-3891b747f1d8>";+u.sip!devicename.ccm.cisco.com="SEP3891B747F1D8";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Sep 12 04:56:10.151: //710061/298E8C7FB1BB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:188@172.17.40.8>;tag=767D3A9E-20D8
CSeq: 6588 REGISTER
Contact: <sip:188@172.17.40.141:5060>;expires=120
Expires: 120
Content-Length: 0
The sip debug you posted shows that the 186 phone sent an invite with a video m= line including video codecs, but when the CUCME sent an invite to the 185 phone the m= line for video contained only the "255" codec which is "no codec" (so no video).
From the SIP INVITE from 186 to CUCME:
From CUCME to 185:
Did you remove the "codec g711ulaw" from both the 186 phone and the 185 phone voice register pools?
Maren
Yes madam... I have removed "codec g711ulaw" from both the 186 and 185 voice register pools.
