Video Conferencing on ISR G2 PVDM3
I'm working on configuring Video conferencing bridge on Cisco 2921 router , but i can't add the command part : "video homogeneous" in the "dspfarm profile 1 conference " command
Do youy have any suggestions .
Ahmed
You seem to be on 15.1(3)T4 and respective command is available from 15.1(4)M. IMO you need to upgrade IOS else wait if Deji has some other point on it.
- Vivek
9 Replies 9
Vivek Batra
Please check and verify the following configuration;
voice-card x
  dspfarm
  dsp services dspfarm
  voice-service dsp-reservation xx
- Vivek
Thanks Vivik , they are inserted but i can't also add the reservation command (command unrecognized )
What IOS are you running..
Can you send
sh version
sh diag
Please rate all useful posts
Hi Ayodeji , please find them attached here
- Vivek
Many thanks Vivik .
Ahmed
Please note that video conferencing is supported since 15.1(4)M till 15.5(3)M. On which version you are?
http://www.cisco.com/c/en/us/products/collateral/unified-communications/tdm-gateways/bulletin-c25-735945.html
- Vivek
Sreekanth Narayanan
Ahmed, please note that Video conferencing and transcoding on the PVDM3 modules is not longer supported by Cisco. The alternative solution for the customers now is to move to the Cisco TelePresence Multipoint Control Units (MCUs) which are being marketed as the solution for video conferencing and also support transcoding.
Hi Sreekanth
Thanks , i got that response from them .
even they gave it a bug ID : CSCus97643
Ahmed
