view extension on jabber contact
nicanor00
I have CUCM and IM 12
I import LDAP user in CUCM
I can view LDAP contact in jabber with their office phone number. But I cannot view thein internal extension number configured in the CUCM
How can I do to have also CUCM internal number on each jabber contact ?
Jaime Valencia
That information is pulled from the directory source, if you use LDAP as your directory source, then you need to make sure the internal DN is there as well.
java
if this helps, please rate
As JAVA mentioned, those  details are from AD(if active directory). To see the internal extension, you need to have that on AD.
Response Signature
