Highlighted
Beginner
Viewmail 8.0.3
ENVIRONMENT:
Unity 5.0.1
Windows 7 Enterprise 32-bit
Exchange 2007
MS Outlook 2007
We recently upgraded our Viewmail client on some test workstations from 7.0.2 to 8.0.3 and noticed a significant delay in playback. Also, the progress bar is not synchonized with the playback as it was in previous versions of Viewmail. I found no literature indicating VMO 8.0.3 did not support Unity 5.0.1.  Any thoughts?
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Re: Viewmail 8.0.3
They broke something that was working fine, and due to poor testing, did not even realized. That happens a .lot.
Either you downgrade, or open a TAC case and fight uphill to see the issue acknowledged and fixed.
3 REPLIES 3
Highlighted
Hall of Fame Master
Re: Viewmail 8.0.3
Highlighted
Beginner
Re: Viewmail 8.0.3
Okay, I will try that and I'll post the results.
Beginner
Re: Viewmail 8.0.3
This is TAC's response:
"Per your case, you are hitting defect
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtd90466
Defect indicates that this should be corrected in VMO 8.1."
It looks like I will have to wait until 8.1 it seems.
