ā05-27-2015 11:04 AM - edited ā03-17-2019 03:09 AM
Virgin Mobile Phone rings once and then goes to fast busy when caller id is enabled. Works fine when you take called id off. Other Mobile phones work fine. The call is going into an FXO port on a Cisco 2911 Version 15.2(4)M4. We are running call Cisco Manager 9.1.. A debug of the call is attached. Below is the FXO port config on the router. This is a problem on several different gatways.
voice-port 0/1/3
trunk-group FXO
timing hookflash-out 50
timing guard-out 1000
connection plar 5700
caller-id enable
ā05-27-2015 05:13 PM
Can you try adding
voice-port 0/1/3
shut
caller-id alerting dsp-pre-alloc
no shut
to your config and retest
Alex
ā05-28-2015 12:19 PM
I tried that config and the call goes in but I only get "From O" as my caller ID on all calls.
