I'm trying to setup Visual VM using CUCM as the call manager but Asterisk PBX as the VM server.
I've followed these steps https://github.com/reillychase/FreePBX-Cisco-SPA-Visual-Voicemail
I'm using a CISCO 8865 to test. The question I have -- When setting up the "Phone Service" in CUCM, is it possible to include a variable in the service URL for the calling extension.
For example, phone A is using extension 200. Phone B is using 201. The URL in the services configuration is:
http://10.1.1.100/voicemail/voicemail.php?user=<EXTENSION>
I would like <EXTENSION> to automatically be replaced with the phone extension from which the query is being sourced.
Any way to do this intelligently? Or does a custom line key need to be defined for each phone that I want to have use this application?
