519
haouaswajih
Participant
Visual Voicemail issue
Dear Networkers,
I have installed Cisco Unity Connection 7.1(2) and Cisco Unified Communications Manager 7.1(2) successfully. I have also succesffully integrated them.
I tried to implement Visual Voicemail on Cisco 7941, and I was able to login on the service sucessfuly by entring the right PIN. The issue is that when trying to Play the Voice Mail, I am always prompted to enter the PIN !!! I don't know what the matter is? I am able to delete the Voice Mail via Visual Voicemail, but I CAN'T PLAY the Vocie Mail !
Can you please help me? I am really wondering what could the issue be!
Thanks in advance.
Best Regards.
3 REPLIES 3
Marwan ALshawi
Advisor
you mean enter the pin when you dial the VM number ?
phillip0707_2
Beginner
I am experiencing the same issue.  What was the fix for this?
I also have the same problem. Anyone solved this problem?
Tinnakorn
Create
Recognize Your Peers
Content for Community-Ad
