09-18-2012 07:32 AM - edited 03-16-2019 01:15 PM
All,
If I migrate my UC virtual machine infrastructure (CUCM 8.6, CUC 8.6) to new hardware at what point will I be prompted to get an updated license? I just did this for the 2nd subscriber in a cluster and it did not say anything about requiring a new license but I am thinking when I migrate the publisher it will.
Thanks and I rate replies.
Solved! Go to Solution.
09-18-2012 07:44 AM
When you change some of the many parameters that compose the hash from which the license MAC is built from, if you don't change any of them, the license MAC will remain the same.
All those are parameters within CUCM/CUC/CUPS/etc, they are not related to the UCS C or B series.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
09-18-2012 08:44 AM
Hi Scott,
Just in case
Cisco Unified Communications Manager on Virtualized Servers uses a different licensing model than Cisco Unified Communications Manager on an MCS server. The MAC address of the NIC card is no longer used to associate the license to the server.
Instead, the license gets associated to a license MAC, which is a 12 digit HEX value created by hashing the following parameters that you configure on the server:
The ways to obtain the license MAC are as follows:
The process to redeem a Product Activation Key (PAK) for licenses at www.cisco.com/go/license is changed for a license MAC. When redeeming a PAK for a license MAC at this URL, you get prompted to select the type of license that you want to obtain:
After you make this selection, the generation and installation of the license file follows the same process.
When you change any of the parameters that create the license MAC, the license that you obtained with it becomes invalid. You must request a rehosting of the license to obtain a valid license. The old license continues to work for a 30-day grace period.
To rehost your licenses, you must open a case with the licensing team to obtain a license for your replacement server. Contact the licensing team at licensing@cisco.com.
During the grace period, you can change the settings back to the licensed values to make your original license valid again. If you need more than 30 days of grace period, change your settings back to the licensed values, then change them back to the new values that you want to use. You will get another 30- day grace period.
Cheers!
Rob
"Why not help one another on the way" - Bob Marley
09-18-2012 07:44 AM
java
09-18-2012 08:44 AM
Hi Scott,
Just in case
Cheers!
Rob
09-18-2012 04:53 PM
Gentlemen,
thank you both!
09-19-2012 06:26 AM
In addition just heads up for future migrations if you go to version 9 all of this becomes irrelevant as License MAC goes away and all licensing gets tied to ELM.
Chris
