06-18-2023 03:23 AM
Hello Everyone,
I have below two CUCM, one used for Primary and both er for redundancy,
My question do we need VMWAR Software for Two Server or one Software that's enough :
| 1 | Server Call manager | |||
| 1.1 | BE6K-M6-K9 | Cisco Business Edition 6000 (M6) Appliance, Export Restr SW | 2 | |
| 1.2 | CON-SNT-BE6K6KHW | SNTC-8X5XNBD Cisco Business Edition 6000 (M6) Applian | 2 | |
| 1.3 | CAB-9K10A-UK | Power Cord, 250VAC 10A BS1363 Plug (13 A fuse), UK | 4 | |
| 1.4 | VIRT-LIC-NONE | Do not factory-load a virtualization software license | 2 | |
| 1.5 | BE6K-CPU-M6 | Intel 4310T 2.3GHz/105W 10C/15MB DDR4 2667MHz | 2 | |
| 1.6 | BE6K-RAM-M6-M5 | 16GB RDIMM SRx4 3200 (8Gb) | 8 | |
| 1.7 | BE6K-RAIDCTRLR-M6 | Cisco 12G SAS RAID Controller w/4GB FBWC (16 Drv) w/1U Brkt | 2 | |
| 1.8 | BE6K-DISK-M6 | 600GB 12G SAS 10K RPM SFF HDD | 12 | |
| 1.9 | BE6K-PSU-M6 | Cisco UCS 1050W AC Power Supply for Rack Server | 4 | |
| 1.10 | BE6K-TPM-M6 | TPM 2.0, TCG, FIPS140-2, CC EAL4+ Certified, for M6 servers | 2 |
For the below software I will order two servers, is the software enough for two CUCM??
| 1.1 | VMW-VSP-STD-1A= | VMware vSphere 8 Std (1 CPU, 32 Core) 1-yr, Support Required | 1 | |
| 1.2 | CON-ISV1-VSXSTD1A | VSphere Standard for 1 CPU; ANNUAL List 1-YR Reqd | 1 | |
| 1.3 | UCS-VMW-TERMS | Acceptance of Terms, Standalone VMW License for UCS Servers | 1 |
thank you
Solved! Go to Solution.
06-18-2023 07:40 AM
Assuming that you mean VMware? If so you should have a license per server. I’m not an expert on the BE bundle, but from what I understand it should come with all the licensing that you need, including virtualisation.
06-19-2023 04:26 AM
Virtualization is no more bundled with BE and it must be ordered separately.
06-18-2023 07:40 AM
06-18-2023 08:08 AM
Thank Roger,
yes you alright, I need VMW-VSP-STD-1A for Each CPU , each server should have separate Software.
thank you again
06-19-2023 04:26 AM
