You can register the licenses at my.vmware.com, and then get them merged using the license portal. Basically you need to pair up your 1-CPU licenses into 2-CPU licenses.
If you can't do it online you can raise a case with VMware support and they will do it for you. I've found the license portal sometimes fails to merge them (it reports success but does nothing).
Aaron
Aaron
Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
