05-11-2018 10:16 AM - edited 03-17-2019 12:48 PM
I am currently running VMWare 5.5 that was installed using the Cisco image on an HP DL380. I have a VMWare host in our primary and secondary data centers. The primary host contains a publisher/subscriber for CUCM, and a publisher for Unity, UCCX, and CER. The secondary data center host contains subscribers for all of the above
This specific server is separate from our other normal clusters and I have a few questions about this. Can I update VMWare on this server using update manager within vSphere? Can I use vMotion to migrate a CUCM/Unity VM from this Cisco image server to our other normal VMWare servers?
CUCM - System version: 10.5.2.13900-12
VMWare - HPE Customized Image ESXi 5.5.0 Update 3 version 550.9.5.0.33 released on April 2016 and based on ESXi 5.5.0 Update 3 Vmkernel Release Build 3568722
05-11-2018 11:02 AM
For ESXi updates, options, procedures, etc. you can refer to VMware docs, that's not dictated by Cisco.
If your server meets the requirements outlined here for the products, you can use it. As to VMware features and caveats, all the info is here:
05-11-2018 01:44 PM - edited 05-11-2018 01:46 PM
Hi there
NOTE: support varies by app and version. Before reading the best practices below, verify support at Supported Editions and Features of VMware vSphere ESXi, VMware vCenter and VMware vSphere Client.
This feature migrates a live, running Virtual Machine (VM) from one physical server to another.
The following applies to any use of vMotion with UC apps:
This feature automates patching and updating of VMware vSphere hosts and Guest OS.
Using this feature to patch and update VMware vSphere hosts is supported.
However, using this feature to patch and update the guest OS is only supported by some applications and some versions, this is what is shown on this page when referring to VUM support. Note that Cisco Unified Communications applications upgrades, patches and updates can not be delivered through VMware Update Manager.
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
05-11-2018 01:51 PM
Thank you very much for all of this information. I will look through these articles tonight. I do have one remaining question. Our ESX host running the Cisco VM's has a specific version of VMWare installed. I believe this version was used as it contained specific drivers needed by the Cisco VM's running on the server. Will I have any issues if I migrate these apps to another VMWare host that does NOT have this same version of VMWware running?
05-11-2018 01:55 PM
Hi there
As long as you are meeting the virtualization requirements for the hardware to run UC Apps, you should be good. This is the master link for UC, you can go to each sublink to get more details for each particualar app, like CUCM, CUC, IMP
Hope this helps!
Cheers
Rath!
