Vocera smart badge - telephony integration
ameen001
Hi Guys,
I am working on a project where we are introducing Vocera smart badge in our organisation.
we want to enable telephony for the Vocera smart badges.
telephony enables Vocera smart badge to make calls to the desk phones in the organisation, also staff can make calls from their desk phones to Vocera smart badges.
Vocera smart badges works through organisation network through Cisco Access points.
For the telephony feature 3 SIP trunks were created. we also want to assign two DIDs for each SIP trunk.
Is it possible to assign 2 DIDs for each SIP trunk?
thanks
Ameen
Jonathan Schulenberg
Sure. Point as many Route Patterns at the Route List or Trunk as you want. The dialed pattern, subject any transformation, will be sent out the trunk as the Request URI to Vocera.
Hi Jonathan,
thanks for your reply.
but our vendor is saying according to SIP trunk docs from Cisco there is no option to entre DID in SIP trunk.
can you please give me some detailed solution if possible. will be really helpful.
below is the link vendor referring to.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/11_5_1/sysConfig/CUCM_BK_SE5DAF88_00_cucm-system-configuration-guide-1151/CUCM_BK_SE5DAF88_00_cucm-system-configuration-guide-1151_chapter_01110.html
kind regards
Ameen
