Beginner
Voice call issue's
Hi All,
We are facing voice call quality issues and we can Clearly hear the other person  but they cannot hear us.
We have ‘3’ 7911G model IP phones in the office connected to Cisco 877 Adsl router via 3 COM POE Switch.
We are connected to our branch office by Site 2 Site VPN via a 512kb dsl link, but our CUCM( 4.1 Version)  is at head office .
Please advice what can be done to get this fixed…
For reference I’ve attached 877 Router Config..
VPN>en
Password:
VPN#ping
Protocol [ip]:
Target IP address: 172.16.100.1
Repeat count [5]: 100
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 100, 100-byte ICMP Echos to 172.16.100.1, timeout is 2 seconds:
Success rate is 99 percent (99/100), round-trip min/avg/max = 112/182/600 ms
VPN#sh run
Building configuration...
Current configuration : 2535 bytes
version 12.4
no service pad
hostname VPN
boot-start-marker
boot-end-marker
enable secret 5 $1$yMA3$SxI6WfvEtpt3gjAksnuys/
aaa new-model
aaa authentication login default local
aaa authorization network default local
aaa session-id common
dot11 syslog
ip cef
ip dhcp use vrf connected
ip dhcp excluded-address 192.168.3.1
ip dhcp excluded-address 192.168.3.202
ip dhcp pool local
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
   lease 8
ip name-server 212.102.0.10
ip name-server 212.102.0.11
username user password XXXX!
crypto isakmp policy 10
authentication pre-share
crypto isakmp key !XXXXXXXX^& address XX.XX.XX.XX
crypto ipsec transform-set JEDDAH esp-3des esp-md5-hmac
crypto map JEDDAH-VPN 10 ipsec-isakmp
set peer XX.XX.XX.XX
set transform-set JEDDAH
match address 130
archive
log config
  hidekeys
interface Tunnel1
ip address 172.20.0.61 255.255.255.252
tunnel source Dialer0
tunnel destination XX.XX.XX.XX
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 0/35
  encapsulation aal5snap
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 192.168.3.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname dslXXXXX@512.shabakah.net.sa
ppp chap password 0 XXXXXX
ppp pap sent-username dslXXXXX @512.shabakah.net.sa password 0 XXXXX
router rip
version 2
network 172.20.0.0
network 192.168.3.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 172.16.0.0 255.255.0.0 XX.XX.XX.XX
ip route 172.16.100.0 255.255.255.0 Tunnel1
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 120 interface Dialer0 overload
access-list 120 deny   ip 192.168.3.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 120 permit ip 192.168.3.0 0.0.0.255 any
access-list 130 permit ip 192.168.3.0 0.0.0.255 172.16.0.0 0.0.255.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
Everyone's tags (1)
1 REPLY 1
Highlighted
Hall of Fame Master
Voice call issue's
Wrong forum, post in "voice - IP telephony". You can move your post using the actions panel on the right.
