Walkthrough Wednesdays
969
timm
Beginner
Voice call rejected, router thinks it's a modem
I'm getting the following error when I make a voice call into a new 3945 with a NM-8CE1T1-PRI voice card:
*Jun 17 00:40:21.479: ISDN Se1/2:23 Q931: RX <- SETUP pd = 8  callref = 0x0004
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98396
                Exclusive, Channel 22
        Calling Party Number i = 0x2183, '6304687534'
                Plan:ISDN, Type:National
        Called Party Number i = 0x89, '2238'
                Plan:Private, Type:Unknown
        Locking Shift to Codeset 6
        Codeset 6 IE 0x37  i = 0x0400
*Jun 17 00:40:21.479: ISDN Se1/2:23 Q931: Received SETUP  callref = 0x8004 callID = 0x0094 switch = primary-ni interface = User
BMV-IGCN-PSTN3945-03(config)#
*Jun 17 00:40:21.479: ISDN Se1/2:23 **ERROR**: accept_incoming_csm_call: modem problem Bearer capability not available(0x3A): b channel 21, call id 0x94
*Jun 17 00:40:21.479: ISDN Se1/2:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8004
*Jun 17 00:40:21.479: ISDN Se1/2:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x8004
        Cause i = 0x80BA - Bearer capability not available
*Jun 17 00:40:21.611: ISDN Se1/2:23 Q931: RX <- RELEASE pd = 8  callref = 0x0004
*Jun 17 00:40:21.611: ISDN Se1/2:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8004
The Serial Interface is set up the same way I have always done it:
interface Serial1/2:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn supp-service name calling
trunk-group INBOUND
no cdp enable
There are 3 PVDM3-128 modules set up as flex, so I don't think it's a lack of resources.
1 REPLY 1
paolo bevilacqua
Hall of Fame Master
NM-8CE1T1-PRI does not supports voice calls.
Use VWICx for voice calls.
Content for Community-Ad
Spotlight Awards 2021
