Highlighted
Beginner
Voice command "show call active voice brief" showing 0 as ID for the call
Does anybody know if has some configuration that unable the call to show the ID (not the call ID, is the number before the colon) on show call active voice brief on a voice gateway?
Telephony call-legs: 0
SIP call-legs: 2
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 2
0 : 2149 1601540ms.1 (17:17:08.026 BRT Wed Sep 21 2016) +2210 pid:5000 Answer 23484488 active
dur 00:00:13 tx:295/5258 rx:649/12980 dscp:0 media:0 audio tos:0xB8 video tos:0x0
IP 172.20.8.32:22236 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 TextRelay: off Transcoded: No
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long duration call duration:n/a timestamp:n/a
LostPacketRate:0.00 OutOfOrderRate:0.00
0 : 2150 1601550ms.1 (17:17:08.036 BRT Wed Sep 21 2016) +2200 pid:420 Originate 4202002 active
dur 00:00:13 tx:649/12980 rx:295/5258 dscp:0 media:0 audio tos:0xB8 video tos:0x0
IP 172.18.240.7:16328 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 TextRelay: off Transcoded: No
Best regards,
Fabio
2 REPLIES 2
Highlighted
Enthusiast
Check the version of IOS are you running.  There is at least one BUG on this out there but it's for a pretty old version of code.  The BUG notes that there is no planned fix so you might have to poke around to see if that is included in any new versions if you plan to upgrade.
CSCeb41426
Highlighted
My IOS is relatively new: 15.4(3)M5, and I have two enviroments with the same version, but just in one the issue happens!
Content for Community-Ad
