09-29-2015 11:22 PM - last edited on 03-25-2019 08:36 PM by ciscomoderator
Greetings,
I have 2 routers CISCO 3825 with a VIC2 2E/M card and CISCO 2851 with a VIC2 2FXS card on the WAN and want to configure voice communication over VOIP. We have plugged in a phone line on the CISCO 2851 with a VIC2 2FXS and we are getting dial tone but cannot place a call.
What is the best way to do and end to end Test from VIC2 2E/M and VIC 2 2FXS?
Is there any thing i'm missing in the configurations below:
CISCO 3825 VIC2 2E/M
| CISCO 2851 VIC2 2FXS |
voice-port 0/2/0 operation 4-wire type 5 signal immediate cptone GB timeouts call-disconnect 3 connection Tie-line 58 ! voice-port 0/2/1 operation 4-wire type 5 signal immediate cptone GB timeouts call-disconnect 3 connection Tie-line 57 ! ! ! ! dial-peer cor custom ! ! dial-peer voice 55 voip destination-pattern 55.... session target ipv4: Remote IP X.X.X.X ! dial-peer voice 44 pots destination-pattern 44.... ! ! dial-peer voice 48 pots destination-pattern 3... port 0/2/1 | voice-port 2/0 cptone GB timeouts call-disconnect 3 connection Tie-line 44 impedance 600c operation 4-wire type 5 signal immediate ! voice-port 2/1 cptone GB timeouts call-disconnect 3 connection Tie-line 45 impedance 600c operation 4-wire type 5 signal immediate !
dial-peer cor custom ! ! dial-peer voice 44 voip destination-pattern 44.... session target ipv4: Remote IP X.X.X.X ! dial-peer voice 55 pots destination-pattern 55.... port 2/0 !
Solved! Go to Solution.
09-30-2015 02:32 AM
What you connecting to EM port? What are you trying to call? Your dialpeers aren't configured for any protocol which will make them use H323 by default. Did you configure H323 interface on both routers. You are missing codec configuration as well on VoIP dialpeers.
09-30-2015 02:32 AM
