06-15-2018 12:00 PM - edited 03-17-2019 01:01 PM
Hi Guys
I would like know if the all voice gateway family 29xx have support to SIP SRST. If have are there any documentation about this? I read any documentation, but, not stay clear for me.
Wilson
Solved! Go to Solution.
06-22-2018 02:10 PM
06-15-2018 12:23 PM
06-15-2018 12:27 PM
Hi Nipun,
Thanks a lot for Your contact and explanation. I have one doubt: as I know if the gateway is using CUBE function? there are any configuration that shows this?
Thank You,
Wilson
06-15-2018 12:29 PM
06-15-2018 01:36 PM
I think it's a shortcut to say that if "we have dial-peers to send/receive calls from both CUCM and ITSP then it is a CUBE".
The CUBE functionality is more complex than only configure dial-peers. It's the addition of a lot of tools configured on router. First we have to dissociate inbound and outbond dial-peers per destination. Furthermore we can have on CUBE these functionalities:
Dtmf relay
Address hiding
Sip/h323 interworking
TDM Gateway
Enhanced transcoding
Voice policy
Call admission control
VXML
Etc...
All of these features sum up what is
CUBE. And the place to be of a CUBE is in DMZ infrastructure==== PROXY.
06-15-2018 01:40 PM
06-15-2018 01:44 PM
For sure @R0g22, but it's not just "configuring dial-peers" that make router act as CUBE.
06-15-2018 01:50 PM
06-15-2018 02:13 PM - edited 06-15-2018 03:17 PM
Ok, then I ask a simple question: activate the cube licence is needed in witch case?
You have to be more shape when you explain "YES if I just configure 2 VoIP dial-peers pointing to different destinations and have calls going from one to the other traversing an IOS router, it makes it a CUBE".
Is it a sip to sip connection?
H323 to sip ? Etc...
These commands are mandatory on CUBE. This is the sip/h323 interworking.
You haven't got that....it's not a CUBE.
06-15-2018 02:22 PM
No one asked about CUBE licenses.
Read my post again and read what OP asked. The post was related to SIP SRST.
The only thing that makes a router a CUBE is IP to IP. I don't care whether it is SIP or H.323 and irrespective of whether there is ANY interwork or not, it is IP to IP. No one is going into what commands are needed to interwork and what not.
If I have a router with VoIP dial-peers and nothing else, it's pretty obvious that a production router would have everything else configured already for call routing and to act as a CUBE.
06-15-2018 02:46 PM
Copy that @R0g22
I know that this post is related to sip srst.
It's just the shortcut you use to define CUBE which is not so reflective.
Sorry if I hurt you.
06-15-2018 02:51 PM
06-15-2018 03:06 PM
You certainly right @R0g22
But in my mind, explain something like this doesn't permit to the OP to really have the basic aknowledgment. Acknowledgment necessary for him to continue and learn more about that item.
All days, during my course I have to teach, not using shortcuts, but the minimim to have a real picture in order to tickle students's curiosity.
That's fine. Always a pleasure to read your posts.
06-21-2018 12:45 PM
Hi Nipun,
Sorry by delay. Follow the configuration on Gateway
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.06.21 11:20:48 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 13890 bytes
version 15.6
service timestamps debug datetime msec localtime
service sequence-numbers
hostname GW-VOZ-01
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.156-3.M4.bin
boot-end-marker
aqm-register-fnf
card type e1 0 1
no logging queue-limit
logging buffered 10000000
no logging rate-limit
no logging console
no logging monitor
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authentication ppp default local
aaa authorization config-commands
aaa authorization exec default group tacacs+ local if-authenticated
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
aaa session-id common
clock timezone GMT -3 0
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
ip dhcp excluded-address 10.77.35.1 10.77.35.10
ip dhcp excluded-address 10.77.35.250 10.77.35.254
ip dhcp pool VOICE
network 10.77.35.0 255.255.255.0
default-router 10.77.35.254
option 150 ip 10.77.104.2 10.77.42.1
dns-server 10.77.101.11 9.9.9.9
domain-name xpto
no ip domain lookup
ip domain name xpto
ip cef
no ipv6 cef
trunk group PSTN
description --- Outbound PRI Trunk group ---
hunt-scheme sequential both down
translation-profile incoming PSTN-IN
translation-profile outgoing PSTN-OUT
crypto pki trustpoint TP-self-signed-3854930922
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3854930922
revocation-check none
rsakeypair TP-self-signed-3854930922
quit
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
ipv4 10.77.35.0 255.255.255.0
ipv4 10.77.162.1
ipv4 10.77.162.2
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service media-renegotiate
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
session transport tcp
registrar server expires max 600 min 60
asserted-id pai
midcall-signaling preserve-codec
midcall-signaling passthru
g729 annexb-all
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class sip-profiles 1
request REINVITE sdp-header Audio-Attribute modify "inactive" "active"
request ANY sdp-header Audio-Attribute modify "a=sendonly" "a=sendrecv"
request REINVITE sdp-header Connection-Info modify "0.0.0.0" "10.99.8.26"
request REINVITE sdp-header Audio-Connection-Info modify "0.0.0.0" "10.99.8.26"
request ANY sdp-header Audio-Attribute modify "a=inactive" "a=sendrecv"
voice class sip-profiles 2
request REINVITE sdp-header Connection-Info modify "0.0.0.0" "10.99.42.1"
request REINVITE sdp-header Audio-Connection-Info modify "0.0.0.0" "10.99.42.1"
voice class e164-pattern-map 1
description DIDs from Carrier
e164 +5577485146[1-4].
voice class e164-pattern-map 2
description Carrier - BRA DID Ranges
e164 485146[1-4].
voice class e164-pattern-map 99
e164 43[1-4].
voice iec syslog
voice register global
default mode
allow-hash-in-dn
timeouts interdigit 5
system message WAN Outage - Fallback Mode
max-dn 100
max-pool 40
voice register pool 1
translation-profile incoming SRST-IN
id network 10.0.0.0 mask 255.0.0.0
dtmf-relay rtp-nte sip-notify
voice-class codec 1
no vad
voice translation-rule 10
rule 1 /^\([2-5].......\)$/ /+5577\1/
rule 2 /^\([79][6-9].......\)$/ /+5577\1/
rule 3 /^\([1-9][1-9][2-9].......\)$/ /+55\1/
rule 4 /^\([1-37-9][1-9][79]........\)$/ /+55\1/
rule 5 /^\00\(.*\)$/ /+\1/
rule 10 /^\+55\(77485146[1-4].\)/ /+55\1/
rule 20 /^\(.*\)$/ /+\1/
voice translation-rule 20
rule 1 /^\(43[1-4].\)$/ /+55773517\1/
rule 5 /^\(77351743[1-4].\)$/ /+5577\1/
voice translation-rule 30
rule 3 /^\+55\(77351743[1-4].\)/ /\1/
rule 4 /.*/ /7735174310/
rule 5 /^\+.*/ /7735174310/
voice translation-rule 40
rule 1 /^0\([2-9].......\)$/ /\1/
rule 2 /^0\([79]........\)$/ /\1/
rule 3 /^0\(19.\)$/ /\1/
rule 4 /^0\(181\)$/ /\1/
rule 5 /^0\(911\)$/ /\1/
rule 6 /^0\(112\)$/ /\1/
rule 7 /^00\([1-9][1-9][1-9].......\)$/ /083\1/
rule 8 /^00\([1-37-9][1-9][79]........\)$/ /083\1/
rule 9 /^00\([1-37-9][1-9][79].........\)$/ /083\1/
rule 10 /^00\([4-6][1-9]9[6-9].......\)$/ /083\1/
rule 11 /^00\([38]00.......\)$/ /0\1/
rule 12 /^000\([1-9].*\)$/ /0083\1/
rule 99 /^\0\(.*\)$/ /\1/
voice translation-rule 50
rule 1 /^\(43..\)$/ /+5577565546\1/
rule 2 /^0$/ /+557735174310/
voice translation-rule 60
rule 95 /^\+5577\([2-9].......\)/ /0\1/
rule 96 /^\+5577\([79]........\)/ /0\1/
rule 97 /^\+55\([1-9][1-9][2-9].......\)/ /00\1/
rule 98 /^\+55\([1-37-9][1-9][79]........\)/ /00\1/
rule 99 /^\+\([1-9].*\)/ /000\1/
voice translation-rule 99
rule 1 /43\(.*\)/ /+5577351743\1/
voice translation-profile NOPLUS-IN
translate called 60
voice translation-profile PSTN-IN
translate calling 10
translate called 20
voice translation-profile PSTN-OUT
translate calling 30
translate called 40
voice translation-profile SAIDA-SRST
translate calling 1
voice translation-profile SRST-IN
translate called 50
translate redirect-called 50
voice translation-profile Carrier
translate called 99
vxml logging-tag
license udi pid CISCO2921/K9 sn FJC1908A1G2
license accept end user agreement
hw-module pvdm 0/1
username DMISUPORTE privilege 15 password 0 dmisuporte
redundancy
controller E1 0/1/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-30 type r2-digital r2-compelled ani
cas-custom 0
country brazil
metering
collect-call-enable
category 2
answer-signal group-b 1
description GVT
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description ### Voice Interface ###
ip address 10.77.35.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.77.35.26 255.255.255.248
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-export destination 10.70.229.49 9996
ip route 0.0.0.0 0.0.0.0 10.96.42.254 name SW-CORE
ip route 10.63.0.102 255.255.255.255 10.63.3.25 name Carrier-Carrier
ip route 10.63.5.25 255.255.255.255 GigabitEthernet0/1
snmp-server community traps RO SNMP_SERVERS
snmp-server community h0tsauce RW SNMP_SERVERS
tacacs-server host 10.52.198.120
tacacs-server host 10.71.18.13
tacacs-server directed-request
tacacs-server key tccifm
control-plane
voice-port 0/0/0
supervisory disconnect dualtone mid-call
cptone BR
timeouts call-disconnect 5
timeouts wait-release 5
connection plar 6556
shutdown
station-id name TRONCO-NET
voice-port 0/0/1
cptone BR
connection plar 9797
voice-port 0/1/0:0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.96.77.1 identifier 2 version 7.0
sccp ccm 10.96.77.2 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 3 register BR300_711U_MTP
associate profile 1 register BRA_BR300_CFB
associate profile 2 register BRA_BR300_XCODE
associate profile 4 register BR300_711A_MTP
associate profile 5 register BR300_729R8_MTP
keepalive retries 5
switchover method immediate
switchback method immediate
dspfarm profile 2 transcode
codec g729br8
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 3
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 3
dspfarm profile 3 mtp
codec g711ulaw
maximum sessions software 50
dspfarm profile 4 mtp
codec g711ulaw
maximum sessions software 100
shutdown
dspfarm profile 5 mtp
codec g711ulaw
shutdown
dial-peer voice 110 voip
description Outbound calls to PSTN
destination-pattern 0T
session protocol sipv2
session target ipv4:10.29.0.107
session transport udp
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
voice-class sip early-offer forced
voice-class sip profiles 1
voice-class sip bind control source-interface GigabitEthernet0/1
voice-class sip bind media source-interface GigabitEthernet0/1
dtmf-relay rtp-nte sip-kpml
no vad
dial-peer voice 150 voip
translation-profile outgoing Carrier
preference 1
modem passthrough nse codec g711ulaw
session target ipv4:10.29.0.108
destination e164-pattern-map 99
voice-class codec 1
voice-class sip profiles 2
voice-class sip bind control source-interface GigabitEthernet0/0
voice-class sip bind media source-interface GigabitEthernet0/0
fax rate 14400
fax protocol pass-through g711ulaw
no vad
dial-peer voice 250 voip
preference 2
session target ipv4:10.77.92.2
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1000 voip
description Outbound calls from UCM
translation-profile incoming NOPLUS-IN
incoming called-number ^0T
voice-class codec 1
no vad
dial-peer voice 1001 voip
description Inbound calls from Carrier
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1 pots
incoming called-number 7171
direct-inward-dial
dial-peer voice 3 voip
preference 1
destination-pattern 7171
session target ipv4:10.77.62.1
dtmf-relay cisco-rtp
dial-peer voice 30 voip
preference 2
session target ipv4:10.77.66.2
gateway
timer receive-rtp 1200
sip-ua
retry invite 2
timers trying 300
g729-annexb override
gatekeeper
shutdown
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.96.42.1 port 2000
max-ephones 40
max-dn 80
system message primary WAN Outage - Fallback Mode
conference transfer-pattern
call-forward busy 4310
call-forward noan 4310 timeout 40
time-format 24
date-format dd-mm-yy
vstack
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 0 0
privilege level 15
transport input telnet ssh
line vty 5 15
exec-timeout 0 0
privilege level 15
scheduler allocate 20000 1000
ntp server 10.77.62.1
ntp server 10.77.62.2
end
BRSPCUR-GW-VOZ-01# sh version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.6(3)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Mon 05-Feb-18 11:22 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
BRSPCUR-GW-VOZ-01 uptime is 1 week, 2 days, 17 hours, 6 minutes
System returned to ROM by reload at 18:12:14 GMT Mon Jun 11 2018
System restarted at 18:13:59 GMT Mon Jun 11 2018
System image file is "flash:c2900-universalk9-mz.SPA.156-3.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FJC1908A1G2
3 Gigabit Ethernet interfaces
1 terminal line
1 Channelized E1/PRI port
2 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO2921/K9 FFFFFFFFFFFF
Suite License Information for Module:'c2900'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
datak9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
GW-VOZ-01#
06-22-2018 01:57 AM
