10-12-2017 03:43 AM - edited 03-17-2019 11:21 AM
I have the following scenario:
I would like to have the analogue phones call the Cisco IP Phones. The question is:
Solved! Go to Solution.
10-12-2017 04:12 AM
Do you have the ability to connect a E1/T1 to this analog PBX?
If so, you'll need a T1/E1 card in your WAN router, for example: VWIC3-1MFT-T1/E1.
Can you show us the output of "show inventory" from your WAN router?
10-12-2017 06:25 AM
10-12-2017 06:32 AM
10-12-2017 04:12 AM
10-12-2017 06:09 AM
Hi Slavik,
This is a design scenario. Assume the Analogue PBXs do not have E1 ports and have only
Kindly advice on the following:
10-12-2017 06:25 AM
10-20-2017 06:11 AM
Slavik,
Thank you.
10-12-2017 06:32 AM
10-20-2017 06:12 AM
Rajan,
Thank you.
