Voice Gateway Security
opnineopnine
Beginner
Beginner
Hi all,
We have one customer with a voice gateway 2800 series that is connected directly to the wan, I would like to know for the security configuration what will be the recommendations for this type of scenario.
Thanks all.
Brandon Pierce
Enthusiast
Enthusiast
That's a pretty broad statement.  If you are using the gateway as a CUBE you can use ip trusted authenticate conditions which will reject anything not on the ip trusted list.
Hi all,
I did an Nmap to the device and this is the output
Host is up (0.035s latency).
Not shown: 987 closed ports
PORT     STATE    SERVICE
22/tcp   open     ssh
23/tcp   open     telnet
37/tcp   filtered time
80/tcp   open     http
443/tcp  open     https
1720/tcp open     H.323/Q.931
2000/tcp open     cisco-sccp
2002/tcp open     globe
4002/tcp open     mlchat-proxy
5060/tcp open     sip
5061/tcp open     sip-tls
6002/tcp open     X11:2
9002/tcp open     dynamid
Dennis Mink
Advisor
Advisor
start off with best practice configuration.
-no ip http server
-encrypt passwords.
-only ssh access
-vty time outs.
-access lists on vty and SNMP (at least write string)
start off with that
Please remember to rate useful posts, by clicking on the stars below.
Recognize Your Peers
