09-10-2011 04:27 AM - edited 03-16-2019 06:55 AM
None of the debug commands like show isdn q931 or show voice ccapi inout is running in my voice gateway 3925 . am not being able check my incoming and outgoing calls. Can anyone help me with this..
09-10-2011 04:47 AM
Did you do a term mon?
Also do you have logging enabled on a buffer. Can you do show log.
09-10-2011 06:21 AM
Hi Sayantani
The debug commands are
debug isdn q931 & debug voice ccapi inout. It should work if you do term mon as suggested by Payal.
But I hope you are not using
show isdn q931 &show voice ccapi inout as you have mentioned here.
Senthil
09-10-2011 09:40 AM
Hi All,
Though i have given those two commands mentioned by senthil n payal , it was not working .
But after giving the command "logging monitor debugging" it worked.
Thanks.
