Sat Jul 11 04:01:34 2015: <191>481335763: Jul 11 04:01:45.659: ISDN Se0/1/1:15 Q931: RX <- SETUP pd = 8 callref = 0x0237
Sat Jul 11 04:01:34 2015: <191>481335764: Sending Complete
Sat Jul 11 04:01:34 2015: <191>481335765: Bearer Capability i = 0x8090A3
Sat Jul 11 04:01:34 2015: <191>481335766: Standard = CCITT
Sat Jul 11 04:01:34 2015: <191>481335767: Transfer Capability = Speech
Sat Jul 11 04:01:34 2015: <191>481335768: Transfer Mode = Circuit
Sat Jul 11 04:01:34 2015: <191>481335769: Transfer Rate = 64 kbit/s
Sat Jul 11 04:01:34 2015: <191>481335770: Channel ID i = 0xA18389
Sat Jul 11 04:01:34 2015: <191>481335771: Preferred, Channel 9
Sat Jul 11 04:01:34 2015: <191>481335772: Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Sat Jul 11 04:01:34 2015: <191>481335773: Calling Party Number i = 0x21A3, '0750XXXXXXXX'
Sat Jul 11 04:01:34 2015: <191>481335774: Plan:ISDN, Type:National
Sat Jul 11 04:01:34 2015: <191>481335775: Called Party Number i = 0xC1, '8437XXXX'
Sat Jul 11 04:01:34 2015: <191>481335776: Plan:ISDN, Type:Subscriber(local)
Sat Jul 11 04:01:34 2015: <191>481335777: Jul 11 04:01:45.659: ISDN Se0/1/1:15 Q931: Received SETUP callref = 0x8237 callID = 0x2F21 switch = primary-net5 interface = User
Sat Jul 11 04:01:34 2015: <191>481335778: Jul 11 04:01:45.667: //-1/53617029A99F/CCAPI/cc_api_display_ie_subfields:
Sat Jul 11 04:01:34 2015: <191>481335779: cc_api_call_setup_ind_common:
Sat Jul 11 04:01:34 2015: <191>481335780: cisco-username=
Sat Jul 11 04:01:34 2015: <191>481335781: ----- ccCallInfo IE subfields -----
Sat Jul 11 04:01:34 2015: <191>481335782: cisco-ani=0750XXXXXXXX
Sat Jul 11 04:01:34 2015: <191>481335783: cisco-anitype=2
Sat Jul 11 04:01:34 2015: <191>481335784: cisco-aniplan=1
Sat Jul 11 04:01:34 2015: <191>481335785: cisco-anipi=1
Sat Jul 11 04:01:34 2015: <191>481335786: cisco-anisi=3
Sat Jul 11 04:01:34 2015: <191>481335787: dest=8437XXXX
Sat Jul 11 04:01:34 2015: <191>481335788: cisco-desttype=4
Sat Jul 11 04:01:34 2015: <191>481335789: cisco-destplan=1
Sat Jul 11 04:01:34 2015: <191>481335790: cisco-rdie=FFFFFFFF
Sat Jul 11 04:01:34 2015: <191>481335791: cisco-rdn=
Sat Jul 11 04:01:34 2015: <191>481335792: cisco-rdntype=-1
Sat Jul 11 04:01:34 2015: <191>481335793: cisco-rdnplan=-1
Sat Jul 11 04:01:34 2015: <191>481335794: cisco-rdnpi=-1
Sat Jul 11 04:01:34 2015: <191>481335795: cisco-rdnsi=-1
Sat Jul 11 04:01:34 2015: <191>481335796: cisco-redirectreason=-1 fwd_final_type =0
Sat Jul 11 04:01:34 2015: <191>481335797: final_redirectNumber =
Sat Jul 11 04:01:34 2015: <191>481335798: hunt_group_timeout =0
Sat Jul 11 04:01:34 2015: <191>481335799: Jul 11 04:01:45.667: //-1/53617029A99F/CCAPI/cc_api_call_setup_ind_common:
Sat Jul 11 04:01:34 2015: <191>481335800:
Sat Jul 11 04:01:34 2015: <191>481335801: Interface=0x1402A198, Call Info(
Sat Jul 11 04:01:34 2015: <191>481335802: Calling Number=0750XXXXXXXX,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Restricted),
Sat Jul 11 04:01:34 2015: <191>481335803: Called Number=8437XXXX(TON=Subscriber, NPI=ISDN),
Sat Jul 11 04:01:34 2015: <191>481335804: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Sat Jul 11 04:01:34 2015: <191>481335805: Incoming Dial-peer=40223, Progress Indication=NOT END TO END ISDN(1), Calling IE Present=TRUE,
Sat Jul 11 04:01:34 2015: <191>481335806: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Sat Jul 11 04:01:34 2015: <191>481335807: Jul 11 04:01:45.667: //-1/53617029A99F/CCAPI/ccCheckClipClir:
Sat Jul 11 04:01:34 2015: <191>481335808: In: Calling Number=0750XXXXXXXX(TON=National, NPI=ISDN, Screening=Network, Presentation=Restricted)
Sat Jul 11 04:01:34 2015: <191>481335809: Jul 11 04:01:45.667: //-1/53617029A99F/CCAPI/ccCheckClipClir:
Sat Jul 11 04:01:34 2015: <191>481335810: Out: Calling Number=0750XXXXXXXX(TON=National, NPI=ISDN, Screening=Network, Presentation=Restricted)
Sat Jul 11 04:01:34 2015: <191>481335811: Jul 11 04:01:45.667: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sat Jul 11 04:01:34 2015: <191>481335812:
Sat Jul 11 04:01:34 2015: <191>481335813: Jul 11 04:01:45.667: :cc_get_feature_vsa malloc success
Sat Jul 11 04:01:34 2015: <191>481335814: Jul 11 04:01:45.667: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sat Jul 11 04:01:34 2015: <191>481335815:
Sat Jul 11 04:01:34 2015: <191>481335816: Jul 11 04:01:45.667: cc_get_feature_vsa count is 3
Sat Jul 11 04:01:34 2015: <191>481335817: Jul 11 04:01:45.667: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sat Jul 11 04:01:34 2015: <191>481335818:
Sat Jul 11 04:01:34 2015: <191>481335819: Jul 11 04:01:45.667: :FEATURE_VSA attributes are: feature_name:0,feature_time:679463288,feature_id:31366532
Sat Jul 11 04:01:34 2015: <191>481335820: Jul 11 04:01:45.667: //36072660/53617029A99F/CCAPI/cc_api_call_setup_ind_common:
Sat Jul 11 04:01:34 2015: <191>481335821:
Sat Jul 11 04:01:35 2015: <191>481335822: Set Up Event Sent;
Sat Jul 11 04:01:35 2015: <191>481335823: Call Info(Calling Number=0750XXXXXXXX(TON=National, NPI=ISDN, Screening=Network, Presentation=Restricted),
Sat Jul 11 04:01:35 2015: <191>481335824: Called Number=8437XXXX(TON=Subscriber, NPI=ISDN))
Sat Jul 11 04:01:35 2015: <191>481335825: Jul 11 04:01:45.667: //36072660/53617029A99F/CCAPI/cc_process_call_setup_ind:
Sat Jul 11 04:01:35 2015: <191>481335826: Event=0x13D36390
Sat Jul 11 04:01:35 2015: <191>481335827: Jul 11 04:01:45.667: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Sat Jul 11 04:01:35 2015: <191>481335828: Try with the demoted called number 8437XXXX
Sat Jul 11 04:01:35 2015: <191>481335829: Jul 11 04:01:45.667: //36072660/53617029A99F/CCAPI/ccCallSetContext:
Sat Jul 11 04:01:35 2015: <191>481335830: Context=0x1009170
Sat Jul 11 04:01:35 2015: <191>481335831: Jul 11 04:01:45.667: //36072660/53617029A99F/CCAPI/cc_process_call_setup_ind:
Sat Jul 11 04:01:35 2015: <191>481335832: >>>>CCAPI handed cid 36072660 with tag 40223 to app "_ManagedAppProcess_CSYW"
Sat Jul 11 04:01:35 2015: <191>481335833: Jul 11 04:01:46.671: //36072660/53617029A99F/CCAPI/ccCallSetupAck:
Sat Jul 11 04:01:35 2015: <191>481335834: Call Id=36072660
Sat Jul 11 04:01:35 2015: <191>481335835: Jul 11 04:01:46.671: //36072660/53617029A99F/CCAPI/cc_api_set_transfer_info:
Sat Jul 11 04:01:35 2015: <191>481335836: Transfer Number=, Transfer Reason=0x0
Sat Jul 11 04:01:35 2015: <191>481335837: Jul 11 04:01:46.671: //36072660/53617029A99F/CCAPI/ccCallProceeding:
Sat Jul 11 04:01:35 2015: <191>481335838: Progress Indication=NULL(0)
Sat Jul 11 04:01:35 2015: <191>481335839: Jul 11 04:01:46.671: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
Sat Jul 11 04:01:35 2015: <191>481335840: mempool not found from usrContainer(2862DCC8)
Sat Jul 11 04:01:35 2015: <191>481335841: Jul 11 04:01:46.671: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Sat Jul 11 04:01:35 2015: <191>481335842: Mempool(23FB00AC) created in usrContainer(2862DCC8)
Sat Jul 11 04:01:35 2015: <191>481335843: Jul 11 04:01:46.675: //36072660/53617029A99F/CCAPI/ccCallSetupRequest:
Sat Jul 11 04:01:35 2015: <191>481335844:
Sat Jul 11 04:01:35 2015: <191>481335845: Destination=, Calling IE Present=TRUE, Mode=0,
Sat Jul 11 04:01:35 2015: <191>481335846: Outgoing Dial-peer=2000, Params=0x279B6CA8, Progress Indication=NOT END TO END ISDN(1)
Sat Jul 11 04:01:35 2015: <191>481335847: Jul 11 04:01:46.675: //36072660/53617029A99F/CCAPI/ccCheckClipClir:
Sat Jul 11 04:01:35 2015: <191>481335848: In: Calling Number=0750XXXXXXXX(TON=National, NPI=ISDN, Screening=Network, Presentation=Restricted)
Sat Jul 11 04:01:35 2015: <191>481335849: Jul 11 04:01:46.675: //36072660/53617029A99F/CCAPI/ccCheckClipClir:
Sat Jul 11 04:01:35 2015: <191>481335850: Out: Calling Number=0750XXXXXXXX(TON=National, NPI=ISDN, Screening=Network, Presentation=Restricted)
Sat Jul 11 04:01:35 2015: <191>481335851: Jul 11 04:01:46.675: //36072660/53617029A99F/CCAPI/ccCallSetupRequest:
Sat Jul 11 04:01:35 2015: <191>481335852: Destination Pattern=8..., Called Number=8007, Digit Strip=FALSE
Sat Jul 11 04:01:35 2015: <191>481335853: Jul 11 04:01:46.675: //36072660/53617029A99F/CCAPI/ccCallSetupRequest:
Sat Jul 11 04:01:35 2015: <191>481335854: Calling Number=0750XXXXXXXX(TON=National, NPI=ISDN, Screening=Network, Presentation=Restricted),
Sat Jul 11 04:01:35 2015: <191>481335855: Called Number=8007(TON=Subscriber, NPI=ISDN),
Sat Jul 11 04:01:35 2015: <191>481335856: Redirect Number=, Display Info=--CVP_9_0_1_0_0_0_670
Sat Jul 11 04:01:35 2015: <191>481335857: Account Number=, Final Destination Flag=TRUE,
Sat Jul 11 04:01:35 2015: <191>481335858: Guid=53617029-2675-11E5-A99F-30F70DB2BB00, Outgoing Dial-peer=2000
Sat Jul 11 04:01:35 2015: <191>481335859: Jul 11 04:01:46.675: //36072660/53617029A99F/CCAPI/cc_api_display_ie_subfields:
Sat Jul 11 04:01:35 2015: <191>481335860: ccCallSetupRequest:
Sat Jul 11 04:01:35 2015: <191>481335861: cisco-username=
Sat Jul 11 04:01:35 2015: <191>481335862: ----- ccCallInfo IE subfields -----
Sat Jul 11 04:01:35 2015: <191>481335863: cisco-ani=0750XXXXXXXX
Sat Jul 11 04:01:35 2015: <191>481335864: cisco-anitype=2
Sat Jul 11 04:01:35 2015: <191>481335865: cisco-aniplan=1
Sat Jul 11 04:01:35 2015: <191>481335866: cisco-anipi=1
Sat Jul 11 04:01:35 2015: <191>481335867: cisco-anisi=3
Sat Jul 11 04:01:35 2015: <191>481335868: dest=8007
Sat Jul 11 04:01:35 2015: <191>481335869: cisco-desttype=4
Sat Jul 11 04:01:35 2015: <191>481335870: cisco-destplan=1
Sat Jul 11 04:01:35 2015: <191>481335871: cisco-rdie=FFFFFFFF
Sat Jul 11 04:01:35 2015: <191>481335872: cisco-rdn=
Sat Jul 11 04:01:35 2015: <191>481335873: cisco-rdntype=-1
Sat Jul 11 04:01:35 2015: <191>481335874: cisco-rdnplan=-1
Sat Jul 11 04:01:35 2015: <191>481335875: cisco-rdnpi=-1
Sat Jul 11 04:01:35 2015: <191>481335876: cisco-rdnsi=-1
Sat Jul 11 04:01:35 2015: <191>481335877: cisco-redirectreason=-1 fwd_final_type =0
Sat Jul 11 04:01:35 2015: <191>481335878: final_redirectNumber =
Sat Jul 11 04:01:35 2015: <191>481335879: hunt_group_timeout =0
Sat Jul 11 04:01:35 2015: <191>481335880: Jul 11 04:01:46.675: //36072660/53617029A99F/CCAPI/ccIFCallSetupRequestPrivate:
Sat Jul 11 04:01:35 2015: <191>481335881:
Sat Jul 11 04:01:35 2015: <191>481335882: Interface=0x2170F60, Interface Type=3, Destination=, Mode=0x0,
Sat Jul 11 04:01:35 2015: <191>481335883: Call Params(Calling Number=0750XXXXXXXX,(Calling Name=0750XXXXXXXX)(TON=National, NPI=ISDN, Screening=Network, Presentation=Restricted),
Sat Jul 11 04:01:35 2015: <191>481335884: Called Number=8007(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
Sat Jul 11 04:01:35 2015: <191>481335885: Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2000, Call Count On=FALSE,
Sat Jul 11 04:01:35 2015: <191>481335886: Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Sat Jul 11 04:01:35 2015: <191>481335887: Jul 11 04:01:46.675: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sat Jul 11 04:01:35 2015: <191>481335888:
Sat Jul 11 04:01:35 2015: <191>481335889: Jul 11 04:01:46.675: :cc_get_feature_vsa malloc success
Sat Jul 11 04:01:35 2015: <191>481335890: Jul 11 04:01:46.675: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sat Jul 11 04:01:35 2015: <191>481335891:
Sat Jul 11 04:01:35 2015: <191>481335892: Jul 11 04:01:46.675: cc_get_feature_vsa count is 4
Sat Jul 11 04:01:35 2015: <191>481335893: Jul 11 04:01:46.675: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sat Jul 11 04:01:35 2015: <191>481335894:
Sat Jul 11 04:01:35 2015: <191>481335895: Jul 11 04:01:46.675: :FEATURE_VSA attributes are: feature_name:0,feature_time:679458136,feature_id:31366533
Sat Jul 11 04:01:35 2015: <191>481335896: Jul 11 04:01:46.675: //36072661/53617029A99F/CCAPI/ccIFCallSetupRequestPrivate:
Sat Jul 11 04:01:35 2015: <191>481335897: SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Sat Jul 11 04:01:35 2015: <191>481335898: Jul 11 04:01:46.675: //36072661/53617029A99F/CCAPI/ccCallSetContext:
Sat Jul 11 04:01:35 2015: <191>481335899: Context=0x279B6C58
Sat Jul 11 04:01:35 2015: <191>481335900: Jul 11 04:01:46.675: //36072660/53617029A99F/CCAPI/ccSaveDialpeerTag:
Sat Jul 11 04:01:35 2015: <191>481335901: Outgoing Dial-peer=2000
Sat Jul 11 04:01:35 2015: <191>481335902: Jul 11 04:01:46.675: //36072661/53617029A99F/CCAPI/cc_api_call_proceeding:
Sat Jul 11 04:01:35 2015: <191>481335903:
Sat Jul 11 04:01:35 2015: <191>481335904: Interface=0x2170F60, Progress Indication=NULL(0)
Sat Jul 11 04:01:35 2015: <191>481335905: Jul 11 04:01:46.679: //36072661/53617029A99F/SIP/Msg/ccsipDisplayMsg:
Sat Jul 11 04:01:35 2015: <191>481335906: Sent:
Sat Jul 11 04:01:35 2015: <191>481335907: INVITE sip:8007@10.22.1.41:5060 SIP/2.0
Sat Jul 11 04:01:35 2015: <191>481335908: Via: SIP/2.0/UDP 10.22.1.38:5060;branch=z9hG4bK258FC81817
Sat Jul 11 04:01:35 2015: <191>481335909: Remote-Party-ID: "--CVP_9_0_1_0_0_0_670" <sip:0750XXXXXXXX@10.22.1.38>;party=calling;screen=yes;privacy=full
Sat Jul 11 04:01:35 2015: <191>481335910: From: "anonymous" <sip:anonymous@10.22.1.38>;tag=AC3B0C4C-948
Sat Jul 11 04:01:35 2015: <191>481335911: To: <sip:8007@10.22.1.41>
Sat Jul 11 04:01:35 2015: <191>481335912: Date: Fri, 10 Jul 2015 20:01:46 GMT
Sat Jul 11 04:01:35 2015: <191>481335913: Call-ID: 53FC787A-267511E5-B108D397-E5272219@10.22.1.38
Sat Jul 11 04:01:35 2015: <191>481335914: Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Sat Jul 11 04:01:35 2015: <191>481335915: Min-SE: 1800
Sat Jul 11 04:01:35 2015: <191>481335916: Cisco-Guid: 1398894633-0645206501-284578226
Sat Jul 11 04:01:35 2015: <191>481335917: 3-0229817088
Sat Jul 11 04:01:35 2015: <191>481335918: User-Agent: Cisco-SIPGateway/IOS-12.x
Sat Jul 11 04:01:35 2015: <191>481335919: Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Sat Jul 11 04:01:35 2015: <191>481335920: CSeq: 101 INVITE
Sat Jul 11 04:01:35 2015: <191>481335921: Max-Forwards: 70
Sat Jul 11 04:01:35 2015: <191>481335922: Timestamp: 1436558506
Sat Jul 11 04:01:35 2015: <191>481335923: Contact: <sip:anonymous@10.22.1.38:5060>
Sat Jul 11 04:01:35 2015: <191>481335924: Expires: 60
Sat Jul 11 04:01:35 2015: <191>481335925: Allow-Events: telephone-event
Sat Jul 11 04:01:35 2015: <191>481335926: X-Cisco-CCBProbe: undefined
Sat Jul 11 04:01:35 2015: <191>481335927: Content-Type: application/sdp
Sat Jul 11 04:01:35 2015: <191>481335928: Content-Disposition: session;handling=required
Sat Jul 11 04:01:35 2015: <191>481335929: Content-Length: 241
Sat Jul 11 04:01:35 2015: <191>481335930:
Sat Jul 11 04:01:35 2015: <191>481335931: v=0
Sat Jul 11 04:01:35 2015: <191>481335932: o=CiscoSystemsSIP-GW-UserAgent 2988 1854 IN IP4 10.22.1.38
