voice hunt-group 1 sequential
kaiwen-bao
Hello, I would like to achieve the following requirement: Dial 307, if there is no answer after 5 seconds, transfer to 382; if there is no answer after 5 seconds, transfer to 363; if there is no answer after 5 seconds, finally transfer to a specific number.
Here is my configuration:
       pilot 307
       list 307, 382, 363
       final 321
       timeout 5
voice register dn  74
      number 307
      name Bao Kaiwen
      label Bao Kaiwen - 307
      voice-hunt-groups login
The current situation is that when I dial 307, it directly transfers to 382, then to 363, and initially, 307 does not ring
Thank you for your help
Rajan
Hi Kaiwen,
Either use a different number for the hunt pilot or if you need the pilot number to be 307, assign a different extension for "voice register dn  74" and include the new number in the hunt list.
Rajan
Please mark all useful posts as helpful and solutions as accepted wherever applicable
Rajan
Hi Kaiwen,
Rajan
