Community Helping Community
401
Highlighted
Beginner
Re: voice hunt-group issue on a 2911.
OK i just wanted to make sure i was following the correct config.  I thought if there is a better way to do this then i am open to that.
Thanks for the reply.
Advisor
Keith,
Is the "AA" a service you have running in CME (i.e. BACD) or is it the attendant application running in CUE? Or something else altogether.  Islam is hunting the the BACD angle here. Your original dial-p suggested you may have AA enabled in CUE (or similar).
To dig deeper, we'll need output from:
show run | s application
show run | s ephone-dn
sh run | s telephony-s
sh run | s dial-peer
If you are trying to use CUE for the AA then we'll need you to session into CUE and provide the output of "show run"
-Bill (@ucguerrilla)
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Beginner
Thanks for all who replied.  This problem has been fixed.
Hunt-Group bug!!
I was using a hunt-group of 100.
voice hunt-group 100 parallel
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtn99445
VIP Mentor
Thanks Keith for updating us. That really was a nasty one..I looked online to see what the issue could be but didnt find anything..Nice work..(+5)
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Content for Community-Ad
FusionCharts will render here
