Walkthrough Wednesdays
1290
Highlighted
%VOICE_IEC-3-GW: CCAPI: Internal Error (Incoming loop) || %CALL_CONTROL-6-CALL_LOOP
We recently enabled voice iec syslog on the CUBEs. Since then, we've been seeing a lot of the below errors. Any suggestion for resolution ?
306619: Sep 18 2017 16:28:43.825 EST: %VOICE_IEC-3-GW: CCAPI: Internal Error (Incoming loop): IEC=1.1.180.1.28.0 on callID 0
306620: Sep 18 2017 16:28:44.328 EST: %CALL_CONTROL-6-CALL_LOOP: The incoming call has a global identifier already present in the list of currently handled calls. It is being refused.
3 REPLIES 3
Highlighted
Hall of Fame Master
Sounds like misconfigured dial-peers, can you post your configuration?
Highlighted
Thanks for your reply. Please find the attached config.
Highlighted
Content for Community-Ad
