Highlighted
Beginner
VOICE Mail access
Hi Guys,
I have CUCM 7.02 up and running .. my voice mail solution is unity connection...
I need to configure the system in such a way so that people from home can check their voice mail...
I have few DID numbers spare ....
Just wanna know how to do that...
I trid to configure it with a translation pattren..
PSTN number converted to voice mail pilot number ... But its not working...
Can anyone help...
regards
5 REPLIES 5
Beginner
Re: VOICE Mail access
Try setting up the incoming DID as a hunt pilot for the Unity ports rather than a translation pattern that points to Unity.
What isn't working specifically?? Unity wont answer or what??
Hall of Fame Cisco Employee
You can configure a translation pattern, translate to VM pilot
In Unity configure direct call routing rule and send them to sign in.
java
if this helps, please rate
java
VIP Advisor
Just make sure that you allow the voice mail boxes to be accessed from different extensions.
in Unity 5 this is done by configuring and alternate extension for a certain subscriber.
for example, if you want john doe to access VM from his mobile (number 123456), allow 123456 as an alternate extension
Please remember to rate useful posts, by clicking on the stars below.
Beginner
If you send them to sign it does the alternate extension thing matter...i didnt think so.
Beginner
Content for Community-Ad
July's Community Spotlight Awards
