Voice mail transfer
fast5658659
Beginner
Beginner
Hi all,
        I have having a weird problem when call is forwarded to voicemail. Consider the follwing scenario
ephone-dn 10
number 202
call-forward all 6200 (e.164 number for vm)
ephone-hunt 1 sequential
pilot 502
list 201
final 6200
timeout 15
If the inbound call hits ephone-dn 10 it will hit the vm service , no problems
But if the inbound call hits ephone-hunt group it says " There is no message associated with this extension" and call disconnects
Any ideas?
CUE version is 3.2.1
CME version is 7.1
William Bell
Advisor
Advisor
Is your expectation that calls to the ephone-hunt should be forwarded to the voicemail box for dn 10?  If so, then I think the behavior you are seeing is correct. Because on this forwarded call, the VM system would see the extension assigned to the ephone-hunt and not the dn/member.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Kenneth Mohammed
Rising star
Rising star
This is because CUE is looking at the original called party number when selecting a voicemail box in which to forward calls. In
this case, its looking for a mailbox with the extension 502, which doesn't exist, hence the error message. I cannot remember off the top of my head whether or not you can configure alternate extensions in CUE, similar to what can be done in full blown Unity, but another remedy would be to configure a translation to translate 502 to 202, and apply to the outbound dial peer pointing to CUE.
example
voice translation-rule 1
rule 1 /502/ /202/
voice translation-profile CUE
translate called 1
dial-peer voice 100 voip
descrip CUE dialpeer
translation-profile outgoing CUE
destination-pattern 6200
session target ipv4:x.x.x.x
session protocol sipv2
dtmf-relay sip-notify
codec g711ulaw
no vad
Let me know if that works for you.
Remember to rate helpful posts.
Thanks all
Problem solved
I created an AA (300) and put in call redirect to 6200 (e.164 number for vm)
changed final to 300 under ephone-hunt
Recognize Your Peers
