Voice-Port and Voip Phone same Ephone-dn?
ken.montgomery
Hi Everyone,  Have a CME running version 15.1.
One of the voice-ports (specifically, voice-port 2/0/10) on the router acting as number 1832.  The users want this number to also ring on two other phones, both of which are IP based (7911 and 7921).  Can you tell me if this is possible?  Adding the ephone-dn to the two IP phones makes the voice-port not ring...
So am looking for a way to make it work on all of these phones... any suggestions?
Thanks in advance,
Ken
18 Replies 18
No good.
Loaded new version, now phones won't register.  Follow threads showing me what to do to recover them, by re-issuing the max-ephones command and still no good, trying to revert to older version now... am in a Bingo situation.
For new versions, you may need to do  "license accept eula end-user" and reload.
Alright, new version loaded, CME up and running.  Making change to add the button that matches the desired analog line to the two IP phones, one at a time and testing as each added.
Adding the desk phone (VOIP 7911) to the analog ephone-dn caused no problems.  Bell works, analogs work and 7911 works.
As soon as you add the same line to a 7921 Wireless though, none ring.
Is there a way around that?
Could be a bug specific to 7921, in that case you would need TAC support.
