Voice ports on G224 problem
Kyle Albasha
                  Some of my voice ports are not getting dial tone . i have compare the config of working port with none working it's the same
running call manager 8.6.2
any idea
thanks
Bruno Rangel
Hi Kyle
You VG is registered with Callmanager?
Please send the both config from the vg and ensure thats is the same in the CUCM gateway configuration.
Please rate this post if helped
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
