07-11-2018 08:12 AM - edited 03-17-2019 01:10 PM
Hi Gents,
Before all thank you for your help. Your experience and expertise are greatly appreciated.
Here you go...
I have a VOIP cluster setup as follow: PSTN -->> CUBE --->>> CUCM --->> UNITY and PTSN ---> CUBE ---> CUCM ---> UCCX.
The issue that i am facing is the voice prompt greeting on the IVR was not registered by a professional service/person. Therefore, i am facing complain where users from the PSTN keeps complain about the quality(volume too low, static). Even internal users as well!
i am thinking to get all the greetings to be registered all together by a PRO but business has been sleeping on it for far too long now.
So i was wondering whether or not i can play with the audio, at least the volume, through CUCM/Unity? I have used audacity in the last for audio manipulation but if the original file is already bad i don't think audacity can help.
Any helps/suggestion will be appreciated.
07-11-2018 08:48 AM
07-11-2018 09:04 AM
07-11-2018 09:37 AM
