Voice Router Prefix adding problem ( iam beginner)
i Configured SIP trunk between Voice Router and Freepbx
the Freepbx Extensions are 3..
i need to add Prefix Number 8 on Voice router , so i will call 83.. instead of 3.. and i need to reach to FreePbx with its original 3..
what i made as below but not worked ( i know i missed something or i misunderstand )
voice translation-rule 5
rule 1 /^8\(3..$\)/ /\1/   ------- need to translate 83.. to 3..
voice translation-profile TO-Egypt
translate calling 5
dial-peer voice 150 voip
description FreePbx outgoing
translation-profile outgoing TO-Egypt
destination-pattern 3..
session protocol sipv2
session target ipv4:xxxxxxxxxxxxxxxxxxx ( that the IP of FreePbx)
dtmf-relay rtp-nte
codec g711ulaw
 i need solutionASAP
If you are dialing 8+3XX the dial peer is wrong, try with:
 destination-pattern 83..
If the connection to Freepbx it is already working, it should work.
Rolando A. Valenzuela.
i will change it tomorrow and i think your solution will work , thank you
