12-21-2016 10:38 PM - edited 03-17-2019 09:01 AM
This my first time to implement a cisco voice system to a client, The requirements are:
1-Support (32) Extension.
2- Support (6) Cisco 7937G IP Conference Station (or any suggestions for alternative models)
3- (32) cisco IP Phone SPA525G (or any suggestions for alternative models)
I am not sure which router should i chose
1-(CISCO2811-K9,PVDM-64,VIC2-4FXO)
2-(CISCO2911V/K9,VIC2-4FXO)
3- Any recommendation but Please take (cost & stability into consideration)
Thanks in advance.
12-22-2016 03:57 AM
Please check the following link for supported endpoints, platforms and IOS/firmware recommendations on CME 11.5
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme115spc.html
For configuring CME you can refer the CME admin guide
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm.html
Manish
12-22-2016 06:43 AM
Alos, I would take a look at new offering BE4000, which is improvement to dated BE6000S:
http://www.cisco.com/c/en/us/products/unified-communications/business-edition-4000/index.html
12-22-2016 06:55 AM
Aside from the recommendations, I would STRONGLY suggest you reach out to a Cisco partner for this, so you can explain them in detail all that you want from the system, and they can propose the right solution, what redundancy you need, and what's your budget.
